PCB Ruler 6 inch
Capacitive Soil Moisture Sensor V1.2
Non-contact Tank Liquid Water Level Sensor 12-24V
Arduino Pro Mini ATMega168
Piezo Speaker 12mm
TEMT6000 Professional Light Sensor Module
BH1750FVI Digital Light Intensity Sensor Module 3-5V
TTP223 One-touch Key Detecting IC
MAX30102 Oximeter Heart Rate Beat Pulse Sensor 1.8-3.3V
TSOP4838 Infrared IR Receiver 38KHz 3-pin
Arduino Sensor Shield V5.0 IO Expansion Board
DC Jack Barrel Connector Male Power Terminal 5.5x2.1mm
Peristaltic Dosing Pump Analytical Lab Aquarium Water Arduino 6V
NodeMCU D1 ESP-12E ESP8266 Shield CH340 WiFi IoT
Solder Wick Length 1m
Solder Mat Heat Resistant Insulator 23x18x0.3cm
ICL7660S CPAZ CMOS Voltage Converter
Arduino Pro Micro ATMega32u4 16MHz 5V
Rotary Encoder Module Brick Sensor KY-040
DHT11 Temperature Humidity Sensor for ESP8266 ESP-01S
TDA2030 Audio Amplifier Module 6-12VDC
Mini VNH2SP30 Stepper Motor Driver Module
RFP70N06 N-Channel 70A 60V MOSFET
TIP42 PNP Epitaxial Silicon Transistor 6A 100V
TIP41 NPN Epitaxial Silicon Transistor 6A 100V
Digital Infrared IR Receiver Module 38KHz for Arduino
1.8 inch 128x160 SPI TFT LCD Display Module
2N3055 NPN Power Transistor (Normal)
Mini W5100 Ethernet Module for Arduino
L298 Dual Full Bridge Motor Driver SMD
LM75A High-speed Temperature Sensor Module I2C
Camera Module v1.3 5MP 1080p 720p for Raspberry Pi 3 and 2
2N3055 NPN Power Transistor (Original)
MUR460 4A 600V Ultra Fast Rectifier
TIP3055 NPN Power Transistor 60V 15A
A2212/5T 2700KV Brushless Outrunner Motor for RC Airplane Aircraft Quadcopter
28Ncm Nema 17 Stepper Motor 0.4A 1.8 4-wire Cable For 3D Printer CNC
Ultra-quiet Brushless Motor Submersible Water Pump 120L/H 3-6VDC
MT2204 II 2300KV Cooling Motor CW/CCW For 250 280 Drone Quadcopter
S9014 NPN Transistor 50V 0.1A
TIP120 NPN Darlington Transistors 60V 5A
FQP30N06 N-Channel MOSFET 60V 32A
NodeMCU ESP-12E ESP8266 WIFI Network Relay Module 220VAC 10A 7-30VDC
Atmel ATTINY85-20PU Microcontroller
FQP50N06 N-Channel MOSFET 60V 50
TDA7313 Digital Controlled Stereo Audio Processor
Mini Solar Powered Car Chassis
Mini Tesla Coil Plasma Speaker 15-24VDC 15W Wireless Transmitter Generator
AM2301 DHT21 Digital Temperature & Humidity Sensor
CNC Shield V4 Engraver 3D Printer Expansion Board A4988 Driver
SMD SMT Chip Test Clip Multimeters Probe Tweezer Y9D7
Super Magnetic High-speed Micro Motor N30 3.7V 0.3A NdFeB
Mini L293D Motor Driver Module
A6 GSM GPRS Quad-band Module with Antenna
TM2313 Three-input Four-channel Digital Control Audio Processor
TG35C60 Isolated Mold Triac 600V 35A (Original)
A4988 Stepper Motor Driver for CNC 3D Printer
2N3773 NPN Bipolar Power Transistor 140V 16A (Original)
ESP-32S WiFi Bluetooth Dual Mode Module (Without Adapter)
TDA7303 Digital Controlled Audio Processor
Mini Fiberglass Alien Across 250mm RC Quadcopter Frame Kit (Unassembled)
KA2803B Earth Leakage Detector
12VDC 1 Way 1 Channel RF Relay Module with Remote Controller 10A 433MHz
12VDC 2 Way 2 Channel RF Relay Module with Remote Controller 10A 433MHz
12VDC 4 Way 4 Channel RF Relay Module with Remote Controller 10A 433MHz
CNC Shield V3 Engraver 3D Printer Expansion Shield A4988 Driver
Non-contact Metal Detector Module 60mm 3-5VDC
Anti-static Brush for PCB Cleaning
2-Axis Servo Bracket Anti-Vibration Camera Mount PT Pan/Tilt SG90
Mini Solar Panel 5V 30mA 53x30mm
TIP127 PNP Darlington Bipolar Power Transistor 100V 5A
TDA7388 Quad BTL Output Power Amplifier with Stand-by & Mute 4x41W (Original)
AS608 Biometric Fingerprint Reader Sensor
Gear Motor 6V 30RPM N20
Gear Motor 12V 300RPM N20
Gear Motor 12V 600RPM N20
Test Hook Clip SMT SMD for Multimeter
Aluminum Heat Sink 8.8x8.8x5mm A4988 IC
Fiberglass 8-inch Paddle Protective Circle for Quadcopter
Blades Propellers with Screws for Syma X5 X5C X5C-1 RC Drone Quadcopter CW/CCW Set
Prototype PCB Board Dual Layer FR4 50x70mm (High Quality) Vero Dot
Prototype PCB Board Dual Layer FR4 40x60mm (High Quality) Vero Dot
Prototype PCB Board Dual Layer FR4 30x70mm (High Quality) Vero Dot
Prototype PCB Board Dual Layer FR4 20x80mm (High Quality) Vero Dot
Double Sided Adhesive 3M White 5mm for Phone LCD Camera Screen Repair per 30cm
Double Sided Adhesive 3M White 10mm for Phone LCD Camera Screen Repair per 30cm
Mini Magnetic Reed Switch Sensor Module For Arduino Smart Car KY-021
Ultrahigh High Speed Micro Mini Coreless Motor 3.7VDC 66000RPM 4x8mm Drone Quadcopter
Intelligent Line Tracking Line Following Smart Car Suite Chassis
Mini Wind Car Chassis Educational Toy
Robot Tank Chassis with Shock Absorbers
RJ45 Ethernet Patch Cord CAT5 1m
4-Channel 433MHz Wireless RF Remote Controller (with receiver)
Mechanical Robot Arm Alloy
Logic Probe High Frequency Response DTL TTL LP-1
ESP-32 Adapter
HM-11 CC2541 Bluetooth 4.0 BLE Uart Transceiver Module JDY-10 (Without Adapter)
A3144 Hall Effect Sensor
6-DOF 3D Rotating Mechanical Robot Arm
Logic Probe Circuit Debugger Level Tester 3.3-5V
TRONIC.LK Item List 1801-1900
Post by TRONICLK » Mon Mar 11, 2019 4:20 am
