PCA9685 16-Ch 12-bit PWM I2C Servo Motor Driver Module for Arduino
Electret Condenser Microphone (Big pin) 9x7
HM-10 CC2541 Bluetooth 4.0 BLE UART Transceiver Module (Without Adapter)
LED 4.8mm Oval Red Defused
LED 4.8mm Oval Green Defused
LED 4.8mm Oval Blue Defused
LED 4.8mm Oval Yellow Clear
LED 4.8mm Oval White Defused
Electric Solenoid Valve 1-inch 12VDC NC Brass Water Air 2W-250-25
Student Eperimental Pack Motor Bulb Buzzer Holders Clips
NE5532 Dual Low-Noise High-Speed Audio Operational Amplifier
ICL7667 Dual Power MOSFET Drivers
ME90N03 N-Channel 30-V (D-S) MOSFET
CT60AM-18B IGBT
IRF3205 HEXFET Power MOSFET 55V 110A
KSP44 NPN Epitaxial Silicon Transistor
Stereo To 3RCA Wire Cord 1.5M
Cooling Fan 5V Raspberry Pi
Sunpower Samsung Phone Charger 5V 2A (Good Quality)
LDNIO Apple Charger Auto-ID iPhone (Good Quality)
Atmel ATMEGA32A-PU Microcontroller
TDA8350Q DC-coupled vertical deflection and East-West output circuit
SN74LS151N / 74HC151 8-Line To 1-Line Data Selector/Multiplexer
LA78141 Display Control Vertical Deflection
BU508DF Silicon Diffused NPN Power Transistor
FR4 Dual Side Copper Board A4 Size
Multimeter Probe Wire Cord VHAN 3012A
TV Remote Control SINGER TCL CRT TCL-N
BT139 Triac
MP3 Player MicroSD card
USB Data Cable for Samsung 1.5m (Good Quality)
USB Data Cable for Samsung 2m (Good Quality)
Wireless Door Bell
USB To Mini Type B USB Cable (30cm)
YF-S201 Water Flow Sensor 1-30L/min 1.75MPa 0.5inch
XL-88 500ml Cleaner (WD40)
Drill Chuck Set 5pcs 0.5, 1, 1.5, 2.3, 3mm
PCB Mount Fuse holder 5x20mm
Wire Cutter for Electronics
TA8403K Power Amplifier
CXA1019 AM FM Radio IC
Thermal Cutoffs Fuse 1A/250V 102C
Thermal Cutoffs Fuse 1A/250V 110C
Thermal Cutoffs Fuse 1A/250V 115C
Thermal Cutoffs Fuse 1A/250V 130C
Thermal Cutoffs Fuse 1A/250V 135C
Thermal Cutoffs Fuse 1A/250V 140C
Solder Flux Injection Type RMA-223 10ml
USB Extension Cable Male to Female 1.8m
3.7V 4300mA 18650 Li-ion Rechargeable Battery Clip Type
TV Remote Control TCL LED/LCD RC3000M11
TV Remote Control LG LED/LCD RM-L1162
TA2003 AM FM Radio IC
A968 PNP Transistor
2.8 inch 240x320 SPI TFT LCD Display Touch Screen Shield Module ILI9341 5V 3.3V for Arduino
DHT22 / AM2302 Digital Temperature And Humidity Sensor Module
CP2102 RS232 USB To TTL Converter Module Adapter
Micro USB 5V to 1.8V/3.3V/5V/9V/12V Power Module Breakout DC to DC
Atmel ATTINY84-20PU Microcontroller
NodeMCU ESP8266 WiFi ESP-12E CP2101 IoT Dev Board Module
0.96 inch 128X64 OLED Display Module I2C IIC Serial White
Dual VNH2SP30 Stepper Motor Driver Module
Conductive Ink Pen Black
DAC0808LCN 8-Bit DAC Digital to Analog Converter
L9110S H-bridge Stepper Motor Driver Module
Anti Static ESD Wrist Band Strap Discharge Grounding Prevent Static Shock
Water Pump 6VDC Dosing Peristaltic Aquarium Chemical Lab Analytical
Arduino Leonardo Original Development Board with Micro USB Cable
MAX7219 8-Digit Digital LED Tube Display Module Red
E3F-DS30C4 Optoelectronic Sensor Photoswitch NPN NO 6-36VDC 1.2M Cable
Mini Electric Motor Shaft Drill Chuck 0.3-3.5mm Motor 3.17mm
NodeMCU Lua V3 ESP8266 WiFi CH340 IoT Dev Board Module
LM317 Power Module Linear Converter Buck Step Down Low Ripple
3.5 inch 480x320 SPI TFT LCD Display Touch Screen Shield Module 3.3-5V for Arduino
0.91 inch 128X32 OLED Display Module I2C IIC Serial Blue 3.3-5V
TB6612FNG Dual DC Stepper Motor Driver Module
IRFZ44N N-Channel 49A 55V MOSFET
Glass Fuse 230VAC 0.5A 500mA 5x20mm
Glass Fuse 230VAC 6A 5x20mm
TV Antenna Jack Female
USB Socket Female Type B Vertical
3V Li-Ion Battery CR1632 (Normal)
2SC3467 NPN Epitaxial Planar Silicon Transistor
BS170 Small Signal MOSFET 500mA 60V (eq 2N7000)
TDA7377 2x30W Dual/Quad Power Amplifie
TDA2050 32W Hi-Fi Power Amplifier
CD4051 CMOS Single 8-Channel Analog Multiplexers/Demultiplexerswith Logic Level Conversion
LED Strip Rigid White 3x48 Bulb 4014
TDA1006 Motor Regulator with Automatic Tape-end Indicator
Water Pump Submersible Pool Tank 12VDC 240L/H 3m
Si7021 Humidity Sensor I2C Industrial High Precision
84x48 Nokia 5110 LCD Display Module for Arduino
NodeMCU ESP-32S WiFi Bluetooth Dual Mode IoT Dev Board
Anti-etching PCB Pen
1.44 inch 128x128 SPI TFT LCD Display Module
Water Pump Submersible Pool Tank 4.5-12VDC 350L/H 3m
Car Cigarette Lighter Socket Connector 12V Male with Fuse Red LED
Relay Module for ESP8266 ESP-01S 5V
IO Expansion Module for Arduino Nano v3.0
Battery Voltage Tester for 1-8S Lipo Li-ion Battery Buzzer Alarm Beeper
TRONIC.LK Item List 1701-1800
Post by TRONICLK » Mon Mar 11, 2019 4:19 am
