Soldering Iron Stand
Network Crimping Tool
HY-150 Wire Stripper
Cordless Screwdriver
JK-20 Screw Driver Tool Set
Wire Cutter Small
Wire Cutter PL-726 Keiba Japan
CN20 Contact Cleaner for Electronics
Solder Wire Lead Roll 60/40 0.6mm 50g High Quality
Solder Wire Lead Roll 60/40 0.6mm 100g High Quality
Solder Wire Lead Roll 60/40 0.8mm 50g High Quality
Solder Wire Lead Roll 60/40 0.8mm 100g High Quality
Solder Wire Lead Roll 60/40 0.8mm 200g High Quality
Solder Wire Lead Roll 60/40 1.2mm 50g High Quality
Solder Wire Lead Roll 60/40 1.2mm 100g High Quality
40 Core Multi Colour IDC Flat Wire per Meter
Solder Paste 50g
Ferric Chloride 100ml
Solder Flux Injection Type RMA-223-UV 30ml
30W Soldering Element
40W Soldering Element
Heat-sink Compound Thermal Paste White Bottle 100g
Heat-sink Compound Thermal Paste Tube
WD40 333ml Cleaner
USB To Mini Type B USB Cable 1.5m
Gold Knobs for Rotary Switch Potentiometer Volume Control Pointer Hole 6mm
Silver Knobs for Rotary Switch Potentiometer Volume Control Pointer Hole 6mm
Black Knobs for Rotary Switch Potentiometer Volume Control Pointer Hole 6mm
Twin Speaker Cable White AWG 20 Per Meter
Multi-channel Antenna Cable 0.8mm 75 Ohm Per Meter
3 Core 15A Cable 1.5mm2 Per Meter
Earth Wire 7/0.67 Per Meter
Electric House Wiring Per Meter
Earth Wire 7/0.67 100m Full Roll
Earth Wire 7/0.67 50m Full Roll
Electric House Wiring Brown Cable 100m Full Roll
Electric House Wiring Blue Cable 100m Full Roll
Electric House Wiring Brown Cable 50m Full Roll
Electric House Wiring Blue Cable 50m Full Roll
Electrical Insulation Tape
Surface Panel Light 6W Square Cool
Surface Panel Light 12W Square Cool
Surface Panel Light 18W Square Cool
LED Deluxe Bulb 4.5W B22 Cool
LED Deluxe Bulb 4.5W E27 Cool
LED Deluxe Bulb 4.5W E27 Warm
LED Deluxe Bulb 7W B22 Cool
LED Deluxe Bulb 7W B22 Warm
LED Deluxe Bulb 7W E27 Cool
LED Deluxe Bulb 7W E27 Warm
Orange Blank Plate
Orange 1 Gang Switch
Orange 2 Gang Switch
Orange 3 Gang Switch
Orange 4 Gang Switch
Orange 5 Gang Switch
Orange 1 Gang 2 Way Switch
Orange 2 Gang 2 Way Switch
Orange D-Pole Switch
Orange Bell Press
Orange 5A Plug Base
Orange 13A Plug Base
Orange 15A Plug Base
Orange 5A Plug Top Round Pin
Orange 13A Plug Top Square Pin
Orange 15A Plug Top Round Pin
Orange TV Socket Base
Orange Telephone RJ11 Socket Base
Orange Light Dimmer
Orange Fan Controller
Orange Wire Cord Extension 3m (High Quality)
Orange Wire Cord Extension 5m (High Quality)
Orange B22 Pin Type Holder
Orange E27 Screw Type Holder
Orange Ceiling Rose White
Orange Sigma 6A MCB Life Time Warranty
Orange Sigma 10A MCB Life Time Warranty
Orange Sigma 16A MCB Life Time Warranty
Orange Sigma 20A MCB Life Time Warranty
Orange Sigma 32A MCB Life Time Warranty
Orange Sigma 40A 2-Pole Isolator (Main Switch) Life Time Warranty
Orange Sigma 40A 3-Pole Isolator (Main Switch) Life Time Warranty
Orange Sigma 40A 4-Pole Isolator (Main Switch) Life Time Warranty
Orange Sigma 40A 2-Pole RCD (Trip Switch) Life Time Warranty
Orange Sigma 40A 3-Pole RCD (Trip Switch) Life Time Warranty
Orange Sigma 40A 4-Pole RCD (Trip Switch) Life Time Warranty
GDT Gas Discharge Tube 90V
GDT Gas Discharge Tube 230V
GDT Gas Discharge Tube 400V
Resetable Fuse 500MA
10D391K 390V Metal Oxide Varistor Resistor VDR
14D431K 430V 14MM Metal Oxide Varistor Resistor VDR
14D471K 470V Metal Oxide Varistor Resistor VDR
10D681K 680V Metal Oxide Varistor Resistor VDR
07D220K 22V 7MM Metal Oxide Varistor Resistor VDR
Panel Mount Fuse holder 5x20mm
Glass Fuse 230VAC 5A 5x20mm
Thermal Cutoffs Fuse 10A/250V 240C
ATC/ATO Blade Fuse Auto Car Fuse 3A
ATC/ATO Blade Fuse Auto Car Fuse 15A
TRONIC.LK Item List 1001-1100
Post by TRONICLK » Mon Mar 11, 2019 4:11 am
