Micro Limit Switch with 35mm Lever 5A 250VAC
Micro Limit Switch with 55mm Lever 16A 250VAC
Miniature 2-Way 6-Pin Slide Switch
Push Button 10 x 28mm Yellow
16mm Round Metal Push Button Momentary Switch Green
16mm Round Metal Push Button Momentary Switch Red
Self Locking Red Mushroom Cap Emergency Stop Push Button Switch 660V 10A
SPST Red Light Rectangular Rocker Switch Big 3-Pin 250VAC 15A / 125VAC 20A
3P4T Rotary Switch
Arcade Push Buttons Green
RJ45 Connector Network Crimp
3-Way PCB Mount Wire Clip with Socket (XH-3PX-150MM)
5-Way PCB Mount Wire Clip with Socket (XH-5PX-150MM)
6-Way PCB Mount Wire Clip with Socket (XH-6PX-150MM)
7-Way PCB Mount Wire Clip with Socket (XH-7PX-150MM)
8-Way PCB Mount Wire Clip with Socket (XH-8PX-150MM)
9-Way PCB Mount Wire Clip with Socket (XH-8PX-150MM)
10-Way PCB Mount Wire Clip with Socket (XH-10PX-150MM)
11-Way PCB Mount Wire Clip with Socket (XH-11PX-150MM)
Jumper wire Male-to-Male (1x40-pin)
Jumper wire Male-to-Female (1x40-pin)
Jumper wire Female-to-Female (1x40-pin)
Solderless Project Board Breadboard Jumper Wire Kit
Crocodile Clip Small
Crocodile Clip Big
4-Way Speaker Connector
TV Jack Antenna Male
5A Plug Top Round Pin Normal Quality
Goot Soldering Iron 30W
Goot Soldering Iron 40W
Goot Soldering Iron 60W
Goot Soldering Iron 80W
Goot Soldering Iron Gun Type (TQ-77) (Original)
SMD Rework Soldering Station 852D 952D (Soldering Iron & Hot Air Gun)
SMD Rework Soldering Station 8586 (Soldering Iron & Hot Air Gun)
SMD Rework Soldering Station 936 (Soldering Iron)
Hot Air Gun with LCD 450C 450W
Metal Bit for Soldering Iron
Ceramic Bit for Soldering Iron 40W (B) Sharp Tip
Ceramic Bit for Soldering Iron 60W (B) Sharp Tip
Advanced Ceramic Bit for Professional Soldering
Small Nozzle for Hot Air Gun
Glue Gun Standard 60W
Glue Gun Medium 20W
Glue Stick Large Black
Glue Stick Large Clear
Glue Stick Small Black
Glue Stick Small Clear
Circuit Wire White Full Role
Circuit Wire Pink Full Role
Circuit Wire Orange Full Role
Circuit Wire Black Full Role
Circuit Wire Green Full Role
Circuit Wire Brown Full Role
Twin Cable Power Wire per Meter
Wire Cord Extension Reel 5m 3pin
AC Power Cord for DVD VCR
Vero Board Dot
Vero Board Line
Red Double Ended Crocodile Clip Jumper Wire
Green Double Ended Crocodile Clip Jumper Wire
Yellow Double Ended Crocodile Clip Jumper Wire
White Double Ended Crocodile Clip Jumper Wire
Black Double Ended Crocodile Clip Jumper Wire
Red Hook Clip Test Probe
Green Hook Clip Test Probe
Yellow Hook Clip Test Probe
Blue Hook Clip Test Probe
Black Hook Clip Test Probe
Project Board Breadboard Solderless (16.6x5.5x0.8)
Project Board Breadboard Solderless Transparent (BB-801T)
Project Board Breadboard Solderless (BB-2T3D-01)
L138 Desoldering Pump Sucker
MX-129 Desoldering Pump Sucker
GS-108 Desoldering Pump Sucker
GS-104 Desoldering Pump Sucker
GS-100 Desoldering Pump Sucker
DT830D Digital Pocket Multimeter
MAS830L Digital Multimeter
Brother Analog Multimeter YH-395B
UNI-T UT-33B Digital Multimeter
UNI-T UT-136D Digital Multimeter with NCV Sensor
UNI-T UT-120 Digital Pocket Multimeter
UNI-T UT-58B Digital Multimeter
Sanwa YX360TRF Analog Multimeter (Original)
Sanwa CD800a Digital Multimeter (Original)
DT3266L Digital Clamp Clip-on Multimeter
Multimeter Probe Wire Cord Normal
FM Radio Aerial 79cm
2RCA To 2RCA Wire Cord 1.5M
3RCA To 3RCA Wire Cord 1.5M
Stereo To 2RCA Wire Cord 1.5M
VGA Y Cable
HDMI Cable 1.5m
PCB Drill Set
Drill bit 0.8mm
Drill bit 0.9mm
Drill bit 1mm
Drill bit 1.2mm
Tweezer Metal Non-magnetic Straight Short TS-12 (Normal)
- It is currently Sun Sep 27, 2026 5:51 am
TRONIC.LK Item List 901-1000
Post by TRONICLK » Mon Mar 11, 2019 3:54 am
