8 Ohm 0.5W Speaker 2.25 inch
4 Ohm 3W Speaker 2 inch
8 Ohm 10W Speaker 5.1x4.4 inch Square
8 Ohm 0.5W Speaker 1.3 inch
8 Ohm 5W Speaker 2.75x1.125 inch Square
8 Ohm 0.5W Speaker 0.75 inch
8 Ohm 7W Speaker Round
Intermittent Beep Alarm Buzzer 3-24VDC 90db SFM-27
VIPer22A AC-DC Converters Low Power OFF-Line SMPS
LM311P Analog Comparator
LM339N Analog Comparator
TDA1543 16-bit Dual DAC Chip
TDA2030A 14W Audio Amplifier
TDA2822M 2W Stereo Audio Amplifier
TDA7386 4X40W Audio Amplifiers Quad Bridge Car Radio Amplifier
TDA8425 Audio Hi-Fi Stereo Processor
TDA7294 Stereo Audio Amplifier
LM386 Audio Power Amplifier
LM358N Dual Differential Input Op-Amp Operational Amplifier
LM358MX Op-Amp Operational Amplifier
LM2904 Dual Op-Amp Operational Amplifier
LA3161 Dual Op-Amp Operational Amplifier
OP07CP Low Offset Volt Precision Amplifier
MAX9708ETN Filterless Spread Spectrum Mono/Stereo Class D Amplifier
MAX1664CUP Active Matrix LCD (AMLCD) Supply
MAX6952EPL 4-Wire Interfaced 4-Digit 5.7 Matrix LED Display Driver
MAX7219CNG Serially Interfaced 8-Digit LED Display Driver
MAX7221CWG Serially Interfaced 8-Digit LED Display Driver
MAX7221CNG Serially Interfaced 8-Digit LED Display Driver
LM3914N -1 Dot Bar LED Display Driver
LM8560 Digital Alarm Clock
NE555N General Purpose Single Timer
NE556N General Purpose Dual Bipolar Timer
LM567CN Tone Decoder
LM1036N Dual DC Operated Tone Volume Balance Circuit
74AC14D Hex Inverter Schmitt Trigger SMD
UC3843AN High Performance Current Mode Controller
UC3842AN High Performance Current Mode Controller
MOC3041 Optocoupler
MOC3043 Optocoupler
MOC3063 Optocoupler
MOC3083 Optocoupler
H11AA1 Optocoupler
HPC922 Optocoupler
PC817 Optocoupler
PC123 Optocoupler
HCPL-3700 Avago AC/DC to Logic Interface Optocoupler
ULN2003A 7-Channel NPN Darlington Array DIP
ULN2803AG 8-Channel NPN Darlington Transistor Array
ULN2803APG 8-Channel NPN Darlington Transistor Array
UDN2981LW 8-Channel Source Driver
CD4052BD Multiplexer 8-channel Differential
SN74LS02N NOR Gate 4-channel 2-inputs
SN74LS08N AND Gate 4-channel 2-inputs
SN74LS14N Inverter Schmitt Trigger
SN74LS32N OR Gate 4-channel
SN74LS47N Decoder BCD to 7 Segment
SN74LS48N Seven Segment Decoder
SN74LS74N Dual D-type Positive Edge-triggered Flip-flop
SN74LS86N Quad 2-input Exclusive OR Gate
SN74LS138N Decoder Binary Unit
SN74HC165N Parallel Load Shift Registers
SN74LS19 Hex Schmitt-Trigger Inverter
SN74LS245N Bus Transceivers Octal
SN74HC273N D-type Flip-flop
74HC595N 8-bit Shift Register
74HC595D Serial-in Serial or Parallel-out 8-bit Shift Register
74HC165D Parallel-in Serial-out 8-bit Shift Register
CD4011BE 4-channel NAND Gate
CD4015BE Dual Static Shift Register
CD4016BE Quad Bilateral Switch
CD4017 Decade Counter Divider
CD4067BE Mux Demux 1X16
CD4069BD CMOS Hex Inverter
MAX490CPA Low-Power Slew-Rate-Limited Transceiver
MAX233CPP RS232 5V Multichannel Driver
MAX209CNG RS232 5V Transceiver with 0.1uF External Cap
MAX202CPE Transceivers External Capacitors
MAX485CPA RS-422/RS-485 Interface Transceiver
MAX232 RS232 to TTL Driver Converter
MAX232ESE RS-232 Interface IC
SIM800C GSM GPRS Quad band
SIM808 GSM GPRS GPS Quad Band Wireless
SIM900A GSM GPRS Wireless Module Dual band 900 1800MHz
L298 Dual Full Bridge Motor Driver
L6203 DMOS Full Bridge Driver
L293D Push Pull Four Channel Motor Driver (Good Quality)
TL072CP Low Noise JFET Op-Amp Operational Amplifier
SN74LS193N Synchronous Up Down Decade Counter
PT2262 Remote Control Encoder
DAC0832LCN 8-Bit DAC Digital to Analog Converter
DS1307 Serial Real Time Clock RTC
VLSI VS1011E MP3 Decoder
VLSI VS1053B OGG Vorbis MP3 AAC WMA FLAC MIDI Audio Codec
UA741CP General-Purpose Op-Amp Operational Amplifier
24C02 Serial 2K EEPROM
24C08 Serial 8K EEPROM
TLP293-4 Transistor Output Optocoupler
FDS6675 P-Channel MOSFET
- It is currently Wed Nov 11, 2026 7:01 pm
TRONIC.LK Item List 301-400
Post by TRONICLK » Mon Mar 11, 2019 3:50 am
