C Code for Interfacing SPI module in AVR MCU
Magneto
Post by Magneto » Sat Oct 24, 2009 11:18 pm
spi.h Header File
extern void spi_master_init(void);
extern void spi_slave_init(void);
extern int spi_master_putc(unsigned char data);
extern int spi_slave_getc(void);
spi.c FIle
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/signal.h>
#include "spi.h"
void spi_master_init(void) {
	//Init Master
	// Set MOSI and SCK output, all others input
	DDRB = (1<<DDB2)|(1<<DDB1)|(1<<DDB0);
	//Enable SPI, Master, set clock rate fck/16
	SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0);
	PORTB &= ~(1<<PB0);
void spi_slave_init(void) {
	//Set MISO output, all others input
	DDRB = (1<<DDB3);
	// Enable SPI
	SPCR = (1<<SPE);
int spi_master_putc(unsigned char data) {
	SPDR = data;
	while(!(SPSR & (1<<SPIF)));
	return 0;
int spi_slave_getc(void) {
	//Wait for reception complete
	// Return data register
	//uart_putc(SPDR);
	return SPDR;
/*void spi_master_init(void) {
	char dummy;
	//Init Master
	SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0)|(1<<SPIE);
	dummy = SPSR;
	dummy = SPDR;
	PORTB &= ~(1<<PB0);
	char dummy;
	DDRB = (1<<DDB3);
	// Enable SPI
	SPCR = (1<<SPE)|(1<<SPIE);
	dummy = SPSR;
	dummy = SPDR;
SIGNAL(SIG_SPI) {
	if() {
		uart_putc(SPDR);
	} else {
