C Code for Interfacing UART module in PIC 16F87X
Magneto
Post by Magneto » Sat Oct 24, 2009 9:14 am
serial.h
(356 Bytes) Downloaded 800 times
always.h
(6.24 KiB) Downloaded 700 times
delay.h
(4.8 KiB) Downloaded 702 times
delay.c
(997 Bytes) Downloaded 694 times
#include	<pic.h>
#include	<conio.h>
#include	<stdio.h>
#include	"always.h"
#include	"delay.h"
void serial_setup(void)
	/* relates crystal freq to baud rate - see above and PIC16F87x data sheet under 'USART async. modes'
	BRGH=1, Fosc=3.6864MHz		BRGH=1, Fosc=4MHz      BRGH=1, Fosc=8MHz    BRGH=1, Fosc=16MHz
	Baud		SPBRG             Baud		SPBRG          Baud		SPBRG         Baud		SPBRG
	1200		191               1200		207.3          1200		415.7         9600    103
	2400		95                2400		103.2          2400		207.3         19200		51
	4800		47                4800		51.1           4800		103.2         38400   25
	9600		23                9600		25.0           9600		51.1          57600   16
	19200		11                19200		12.0           19200	25.0          115200  8
	38400		5                 38400		5.5            38400	12.0
	57600		3                 57600		3.3            57600	7.7
	115200	1                 115200	1.2            115200	3.3
	 * Comms setup:
	#define BAUD 19200
	#define DIVIDER ((PIC_CLK/(16UL * BAUD) -1))
	#define HIGH_SPEED 1
	//you can comment these #assert statements out if you dont want error checking
	#if PIC_CLK==3686400 && BAUD==19200
		#assert DIVIDER==11
	#elif PIC_CLK==4000000 && BAUD==19200
		#assert DIVIDER==12
	#elif PIC_CLK==16000000 && BAUD==19200
		#assert DIVIDER==51
	#elif PIC_CLK==20000000 && BAUD==19200
		#assert DIVIDER==64
	#endif
	SPBRG=DIVIDER;
	BRGH=HIGH_SPEED;	//data rate for sending
	SYNC=0;						//asynchronous
	SPEN=1;						//enable serial port pins
	CREN=1;						//enable reception
	SREN=0;						//no effect
	TXIE=0;						//disable tx interrupts
	RCIE=0;						//disable rx interrupts
	TX9=0;						//8-bit transmission
	RX9=0;						//8-bit reception
	TXEN=0;						//reset transmitter
	TXEN=1;						//enable the transmitter
unsigned char dummy;
#define clear_usart_errors_inline	\
if (OERR)													\
	TXEN=0;													\
	TXEN=1;													\
	CREN=0;													\
	CREN=1;													\
if (FERR)													\
	dummy=RCREG;										\
	TXEN=0;													\
	TXEN=1;													\
//writes a character to the serial port
void putch(unsigned char c)
	while(!TXIF)			//set when register is empty
		clear_usart_errors_inline;
		CLRWDT();
	TXREG=c;
	DelayUs(60);
//gets a character from the serial port without timeout
unsigned char getch(void)
	while(!RCIF)
		CLRWDT();
	return RCREG;
unsigned char getch_timeout(void)
	unsigned char i;
	unsigned int timeout_int;
	// retrieve one byte with a timeout
	for (i=2;i!=0;i--)
		timeout_int=timeout_int_us(240000);
		while (hibyte(timeout_int)!=0) //only check the msb of the int for being 0, it saves space, see always.h for macro
			CLRWDT();
			timeout_int--;
			if (RCIF)
				return RCREG;
	return 0;
void clear_usart_errors(void)
writes a character to the serial port in hex
if serial lines are disconnected, there are no errors
void putchhex(unsigned char c)
	unsigned char temp;
	// transmits in hex
	temp=c;
	c=(c >> 4);
	if (c<10) c+=48; else c+=55;
	putch(c);
	c=temp;
	c=(c & 0x0F);
	putch(c);
void putinthex(unsigned int c)
	#define ramuint(x)						(*((unsigned int *) (x)))
	#define ramuint_hibyte(x)			(*(((unsigned char *)&x)+1))
	#define ramuint_lobyte(x)			(*(((unsigned char *)&x)+0))
	#define ramuchar(x)						(*((unsigned char *) (x)))
	putchhex(ramuint_hibyte(c));
	putchhex(ramuint_lobyte(c));
	#undef ramuint(x)
	#undef ramuint_hibyte(x)
	#undef ramuint_lobyte(x)
	#undef ramuchar(x)
//if there has been a previous timeout error from getch_timeout, this returns TRUE
unsigned char usart_timeout(void)
//	return usart_timeout_error;
	return FALSE;
writes a character to the serial port in decimal
void putchdec(unsigned char c)
	unsigned char temp;
	temp=c;
	//hundreds
	if ((c/100)>0) putch((c/100)+'0');
	c-=(c/100)*100;
	//tens
	if (((temp/10)>0) || ((temp/100)>0)) putch((c/10)+'0');
	c-=(c/10)*10;
	//ones
	putch((c/1)+'0');
void putst(register const char *str)
	while((*str)!=0)
		putch(*str);
    if (*str==13) putch(10);
    if (*str==10) putch(13);
		str++;
