301 Redirect
301 redirect is the most efficient and Search Engine Friendly method for URL redirection. It's not that hard to implement and it should preserve your search engine rankings for that particular page. If you have to change file names or move pages around, it's the safest option. The code "301" is interpreted as "moved permanently".
Below is a complete list of methods to implement URL Redirection
IIS Redirect
In internet services manager, right click on the file or folder you wish to redirect
Select the radio titled "a redirection to a URL".
Enter the redirection page
Check "The exact url entered above" and the "A permanent redirection for this resource"
Click on 'Apply'
ColdFusion Redirect
<.cfheader statuscode="301" statustext="Moved permanently">
<.cfheader name="Location" value="http://www.new-url.com">
PHP Redirect
Header( "HTTP/1.1 301 Moved Permanently" );
Header( "Location: http://www.new-url.com" );
ASP Redirect
<%@ Language=VBScript %>
Response.Status="301 Moved Permanently"
Response.AddHeader "Location","http://www.new-url.com/"
ASP .NET Redirect
<script runat="server">
private void Page_Load(object sender, System.EventArgs e)
Response.Status = "301 Moved Permanently";
Response.AddHeader("Location","http://www.new-url.com");
</script>
JSP (Java) Redirect
response.setStatus(301);
response.setHeader( "Location", "http://www.new-url.com/" );
response.setHeader( "Connection", "close" );
CGI PERL Redirect
$q = new CGI;
print $q->redirect("http://www.new-url.com/");
Ruby on Rails Redirect
def old_action
headers["Status"] = "301 Moved Permanently"
redirect_to "http://www.new-url.com/"
end
Redirect Old domain to New domain (htaccess redirect)
Create a .htaccess file with the below code, it will ensure that all your directories and pages of your old domain will get correctly redirected to your new domain.
The .htaccess file needs to be placed in the root directory of your old website (i.e the same directory where your index file is placed)
Options +FollowSymLinks
RewriteEngine on
RewriteRule (.*) http://www.newdomain.com/$1 [R=301,L]
Please REPLACE http://www.newdomain.com in the above code with your actual domain name.
In addition to the redirect I would suggest that you contact every backlinking site to modify their backlink to point to your new website.
Note* This .htaccess method of redirection works ONLY on Linux servers having the Apache Mod-Rewrite moduled enabled.
Redirect to www (htaccess redirect)
Create a .htaccess file with the below code, it will ensure that all requests coming in to domain.com will get redirected to http://www.domain.com
Options +FollowSymlinks
RewriteEngine on
rewritecond %{http_host} ^domain.com [nc]
rewriterule ^(.*)$ http://www.domain.com/$1 [r=301,nc]
Please REPLACE domain.com and http://www.newdomain.com with your actual domain name.
How to Redirect HTML
Please refer to section titled 'How to Redirect with htaccess', if your site is hosted on a Linux Server and 'IIS Redirect', if your site is hosted on a Windows Server.
URL Redirection
Web programming topics
