DC to DC converters are important in portable electronic devices such as cellular phones and laptop computers, which are supplied with power from batteries primarily. Such electronic devices often contain several sub-circuits, each with its own voltage level requirement different than that supplied by the battery or an external supply (sometimes higher or lower than the supply voltage, and possibly even negative voltage). Additionally, the battery voltage declines as its stored power is drained. Switched DC to DC converters offer a method to increase voltage from a partially lowered battery voltage thereby saving space instead of using multiple batteries to accomplish the same thing.
Most DC to DC converters also regulate the output voltage. Some exceptions include high-efficiency LED power sources, which are a kind of DC to DC converter that regulates the current through the LEDs, and simple charge pumps which double or triple the input voltage
Conversion methods
Electronic
Linear
Linear regulators can output a lower, but not a higher, voltage from the input. They are very inefficient if the voltage drop is large and the current high as they dissipate as heat power equal to the product of the output current and the voltage drop; consequently they are not normally used for large-drop high-current applications.
The inefficiency wastes power and requires higher-rated, and consequently more expensive and larger, components. The heat dissipated by high-power supplies is a problem in itself as it must be removed from the circuitry to prevent unacceptable temperature rises.
They are practical if the current is low, the power dissipated being small, although it may still be a large fraction of the total power consumed. They are often used as part of a simple regulated power supply for higher currents: a transformer generates a voltage which, when rectified, is a little higher than that needed to bias the linear regulator. The linear regulator drops the excess voltage, reducing hum-generating ripple current and providing a constant output voltage independent of normal fluctuations of the unregulated input voltage from the transformer / bridge rectifier circuit and of the load current.
Linear regulators are inexpensive, reliable if good heat sinking is used and much simpler than switching regulators. As part of a power supply they may require a transformer, which is larger for a given power level than that required by a switch-mode power supply. Linear regulators can provide a very low-noise output voltage, and are very suitable for powering noise-sensitive low-power analog and radio frequency circuits. A popular design approach is to use an LDO, Low Drop-out Regulator, that provides a local "point of load" DC supply to a low power circuit.
Switched-mode conversion
Electronic switch-mode DC to DC converters convert one DC voltage level to another, by storing the input energy temporarily and then releasing that energy to the output at a different voltage. The storage may be in either magnetic field storage components (inductors, transformers) or electric field storage components (capacitors). This conversion method is more power efficient (often 75% to 98%) than linear voltage regulation (which dissipates unwanted power as heat). This efficiency is beneficial to increasing the running time of battery operated devices. The efficiency has increased since the late 1980's due to the use of power FETs, which are able to switch at high frequency more efficiently than power bipolar transistors, which have more switching losses and require a more complex drive circuit. Another important innovation in DC-DC converters is the use of synchronous rectification which replaces the flywheel diode with a power FET with low "On" resistance, thereby reducing switching losses.
Most DC to DC converters are designed to move power in only one direction, from the input to the output. However, all switching regulator topologies can be made bi-directional by replacing all diodes with independently controlled active rectification. A bi-directional converter can move power in either direction, which is useful in applications requiring regenerative braking.
Drawbacks of switching converters include complexity, electronic noise (EMI / RFI) and to some extent cost, although this has come down with advances in chip design.
DC to DC converters are now available as integrated circuits needing minimal additional components. DC to DC converters are also available as a complete hybrid circuit component, ready for use within an electronic assembly.
Magnetic
In these DC to DC converters, energy is periodically stored into and released from a magnetic field in an inductor or a transformer, typically in the range from 300 kHz to 10 MHz. By adjusting the duty cycle of the charging voltage (that is, the ratio of on/off time), the amount of power transferred can be controlled. Usually, this is done to control the output voltage, though it could be done to control the input current, the output current, or maintain a constant power. Transformer-based converters may provide isolation between the input and the output. In general, the term "DC to DC converter" refers to one of these switching converters. These circuits are the heart of a switched-mode power supply. Many topologies exist. This table shows the most common.
DC to DC Converters
