The Vim Editor Cheat Sheet
Linux OS Topics
Post by Neo » Tue Oct 06, 2009 3:36 pm
If you are a Linux/Unix user, chances are that you are using the well known vim editor for your casual text editing. In case you are not familiar with it, Vim is a text editor that has no GUI and is executed via the unix shell. You may be thinking that this makes it more difficult to use, but once you get to know the basics, you will begin to love the idea that you don’t have to use your mouse to change lines and will also be surprised at its efficiency.
One thing that is arguable about Vim is the fact that it has a pretty large and complicated set of commands that appear daunting to the first time user.Here is a very important reference to the most used vim commands. I suggest that you print this out and have it somewhere close to you in order to get the most out of it.
Return to “Linux”
