The installation process is very simple and nothing to describe anything more here. For more information check:
http://fuse.sourceforge.net/sshfs.html
sshfs creates a group under the name fuse. In order to be able to run an executable as a user, this user should have to be
inside that group, have permissions over the newly mounted file and have execute access at /usr/bin/fusermount and /etc/fuse.conf. These things happen after issuing the commands below:
adduser ForTheWin fuse
mkdir mountDir
chown ForTheWin:fuse mountDir
chown ForTheWin:fuse /dev/fuse
chmod +x /usr/bin/fusermount
chmod +x /etc/fuse.conf
sshfs#[email protected]:/starting/path fuse user,allow_other 0 0And then you can finally mount the filesystem :
sshfs name@remoteHost:remoteFilePath localMountPointCode: Select all
modprobe /dev/fuse
