Just a little technical tip.
If you need to refer a control added to a sheet in Excel from code, make sure to insert an ActiveX rather than a form control. From controls could only be assigned to a macro. With ActiveX, you will be able to do almost everything you do with standard VB.
- It is currently Sun Sep 27, 2026 6:47 am
Excel VBA refering a control such as combo box
Visual Basic Topics
Return to “Visual Basic Programming”
