Space weather report to keep GPS on track
Post by Nipuna » Thu Jan 22, 2015 12:33 am
A flare for trouble (Image: NASA/GSFC/SDO)
We all rely on weather forecasts to plan ahead and ensure our day won't be ruined by an incoming storm. You can even get a minute-by-minute forecast of where you are with a glance at your phone. Not so lucky are those in charge of critical satellite infrastructure that risks being wiped out by a solar storm.
A new forecasting system launching this week aims to change that. Dubbed FLARECAST, it uses the latest in solar physics and high-performance computing to create space weather forecasts as accurate as those for Earth.
Astrophysicists at the US National Oceanic and Atmospheric Administration's (NOAA) Space Weather Prediction Center, and the UK Met Office's Space Weather Operations Centre manually forecast the sun's behaviour just once a day. They scan live streams of data for potentially dangerous bursts of plasma called coronal mass ejections (CMEs).
"Space weather forecasting is probably where terrestrial weather forecasting was 30 years ago," says Catherine Burnett, the Met Office's space weather programme manager. "If we've got a CME en route, we can only give people a window that's plus or minus 6 hours. That's not good enough for them to do proper planning."
FLARECAST will autonomously churn out updated forecasts every minute, and aims to predict when the sun will erupt, not just alert Earth when it already has. The network was switched on at the start of the year and will be officially launched at a conference in Brussels, Belgium, on 15 January.
"In Boulder [at NOAA] they have extremely experienced people, but it's not automated. Someone is sitting there looking at the data," says Manolis Georgoulis of the Academy of Athens, Greece, who is leading the project. "We're trying to rely on fully automated methods."
The system's primary source of data is NASA's Solar Dynamics Observatory, which supplies measurements of magnetic fields on the solar surface as it orbits the sun. Physicists can work back from this data to model the fields in the corona above the surface of the sun. These are too weak to measure directly but are responsible for CMEs, since the coronal fields twist as the surface roils and eventually snap. The energy released can hurl charged particles away from the sun and towards Earth where they damage satellites, knocking out GPS and communications.
While an outage may not have a direct impact on the average person's day, it can be fatal in other arenas. "If you're driving your car and your satnav isn't working for 10 minutes, no big deal," Bill Murtagh of NOAA told policymakers at the Dupont Summit in Washington DC in December. "But if you're landing a plane with quarter-mile visibility and a crosswind in Juneau, Alaska, and you're relying on GPS that's gone for a couple of minutes, you've got a big problem."
The scale and depth of society's dependence on GPS is growing, says Burnett. Oil companies need precision GPS to dock tankers safely in port, large-scale farmers program their tractors with planting or ploughing routes guided by GPS, and financial services use the satellite network to ensure precise timing when executing high-frequency trades.
An extreme example of this dependency comes from Alaska. The state's snow ploughs clear mountain roads in zero visibility , tracing a virtual path with only GPS as their guide. A solar storm and GPS outage could be fatal.
Future humans will have even greater need of accurate, timely space weather forecasts, says Peter Gallagher, a member of the FLARECAST team at Trinity College Dublin, Ireland. Earth's magnetic field protects us from high-speed electrons and protons. In space or on Mars – which has no substantial magnetic field – such solar weather can kill. If we ever want to expand into the solar system, we will need to have a better idea of when deadly weather might hit.
"If you're going to be working on the surface, exploring or tending crops, you're going to have pockets of magnetic field [for shelter] and you need to know what the space weather forecast for today is going to be," says Gallagher. "We'd like to provide that forecast."
This article will appear in print under the headline "And now, the space weather"
