Move over, electrons – circuits could one day be powered by frigid quantum matter.
Ultra-cold clouds of atoms called Bose-Einstein condensates act as a single quantum object, and the goal has been to build "atomtronic" circuits with them. But the condensate's delicate quantum state can easily fall apart.
Now Changhyun Ryu and Malcolm Boshier of the Los Alamos National Laboratory in New Mexico have found a way to do it. Their circuits are built from two laser beams, one that creates a horizontal sheet of light to act as a circuit board, and another vertical laser that traces out the path of the circuit. The condensate, which is made from around 4000 cooled rubidium atoms, is trapped inside the beams by the same forces used to create optical tweezers, which can manipulate particles on a small scale.
The condensate is set in motion by creating a slightly sloped path. The team ran the condensate along straight lines, in a circle and through a Y junction – all essential components of a circuit. Since the circuits are just made from light, they can be reconfigured as the atoms are moving, letting you squeeze a complex circuit into a small space, says Boshier.
The advance could one day be used to build a navigation system that can tell where you are by using the rotation and acceleration of the condensate to track movements from a previous known location. This could be used as a backup for a device that loses contact with GPS satellites. The UK Defence Science and Technology Laboratory is also looking at using condensates to create such a quantum GPS for submarines, but it needs to shrink the technology down first.
Thorsten Schumm of the Vienna University of Technology in Austria says previous experiments using circuits etched on physical chips show more general promise, but he thinks the laser circuits could have their uses. "They can change the circuit easily, whereas we would have to produce a new atom chip every time," he says. "What they have demonstrated so far with it is not really spectacular but the potential is there."
Reference: ArXiv: arxiv.org/abs/1410.8814
Frigid matter powers first quantum circuits
