A implant that trains your brain to stop tinnitus
Post by Nipuna » Tue Jul 29, 2014 12:21 am
Is that ringing in your ears bad enough that you would install a brain implant just to be rid of it? For thousands of Americans, the answer seems to be yes. A series of clinical trials for an implant made by company called MicroTransponder has demonstrated that its new device, which sits by your vagus nerve on your neck, is up to the job. Amusingly enough, though, as with a lot of bleeding-edge neuroscience, the device makers aren’t entirely sure why or how it works.
The implant targets the vagus nerve, also known as cranial nerve X. The X indicates that the nerve is the tenth major nerve to exit the brain counting downwards from the cranial base. If you are under the impression that this nerve is a simple tree with a few terminal branches in various organs, you need to take a closer look. The vagus is actually a whole network of nerves that join and divide at several major hubs deep inside the body. How then do the experts know which part(s) to target? The simple answer is they don’t. In fact, stimulators for the vagus nerve have been used to treat nearly everything under the sun — seizures, depression, tics, obesity, you name it.
One refinement used by MicroTransponder methodology is to pair different kinds of auditory cues with the electrical stimulation to identify the triggers of the tinnitus. Different stimuli can be used to cancel out or mask the tinnitus, and nail down what frequencies it operates at. One presumption of the method is that pairing a series of non-tinnitus tones with the stimulation can reduce the representation in the brain of the tinnitus-linked tones while expanding those of the others. In this way the perception of tinnitus activity is in effect diluted out. Researchers have linked vagus nerve activity directed toward the brain with its detection of adrenalin released by the body. This activity, in theory, reinforces salient events (auditory or otherwise) experienced by the body and reinforces them in the brain.
Much remains to be understood regarding how tinnitus occurs. One idea is that they are linked to natural resonances within the ear called otoacoustic emmisions. While strong emissions can be recorded at the same time as tinnitus is reported for about 10% of afflicted individuals, it does not appear that the emissions are the actual cause. Ideally, implants placed within the auditory brainstem pathways would be able to precisely dial out the offending sounds, but that technology is still a ways off. Last week, for example, a hearing-impaired child was outfitted with such a brainstem impant — for the second time. The first implant was apparently damaged when the child hit their head and had to be replaced.
[media]http://www.youtube.com/watch?feature=pl ... MLbFwltBdc[/media]
For now, vagus nerve implants seem to be the best hope tinnitus suffers might have. Rather than an instantaneous neural reprogramming that short-circuits undesirable sounds and perceptions, the vagal implant is more like braces for the brain. A background influence that works for a while, but may need to be applied again in retraining sessions if the effects where off. As we enter the new age of elective hearing implant technology, we might look forward to even more exotic options — options configured into everyday hearing aids or implants over which we have more precise control.
