Virtual flashlight reveals secrets of ancient artefacts
Post by Nipuna » Mon Jun 30, 2014 11:25 pm
A new way to reveal points of interest (Image: Brett Ridel)
Have a look at any ancient artefact and there's probably something there that you cannot see: stone corners that have long since chipped off; carvings rubbed away by time; or once-glorious colours that have faded. Now those missing features can be brought back to life, thanks to Revealing Flashlight, a system that projects computer-generated models on to real objects, filling in missing details wherever its spotlight lands.
The system has been piloted at the Allard Pierson Museum at the University of Amsterdam in the Netherlands, where it illuminated lost pigmentation on a fragment from an Egyptian tomb. It has also been used to highlight the contours of a 3D-printed replica of a statue of Isis from the Lighthouse of Alexandria, and to help viewers decipher inscriptions on an Egyptian stela.
"We have more and more virtual objects available, either from real objects that have been scanned or virtually created objects that have been 3D printed," says Patrick Reuter, the project's lead researcher at the French Institute for Research in Computer Science and Automation in Rocquencourt.
"But there's information missing. Sometimes you get more from virtual objects, and other information from physical objects." The project was borne out of the desire to combine these two worlds. Using common scanning techniques like structured-light 3D scanning or photogrammetry, Reuter's team creates a computer model of an object. This helps identify important curves and ridges in the object, or missing elements, that could be important to emphasise in the virtual, projected version.
Point, it's slick
When a museum visitor wants to look at an ancient artefact with the aid of the Revealing Flashlight, a LeapMotion gesture-sensing controller tracks where the viewer is pointing by analysing their hand in 3D. A projector on the floor in front of the artefact uses this information to direct the flashlight's projection on to the correct spot.
Besides enhancing museum visits for amateurs, the team also reckons the flashlight could be a valuable tool for archaeologists. By projecting computer-modelling information directly on to objects, it might help researchers piece broken artefacts together or connect hard-to-read engravings.
"It's a great application for use in museums, particularly for visitors who may not have detailed knowledge of the exhibit or artefact," says Susan Yoon at the University of Pennsylvania in Philadelphia.
The system will next appear at exhibits on the Roman Empire at the Amsterdam museum and the Museum of Imperial Forums in Rome, Italy, in September.
