First medical X-ray scanner heads for space station
Post by Nipuna » Mon Jun 23, 2014 11:33 pm
Rats do their bit for space flight (Image: Techshot)
MAKE no bones about it: the International Space Station is about to get its first medical X-ray scanner.
Astronauts will use the device to study the effects on rodents of extended periods of time spent in microgravity.
Bones deteriorate quickly in space, losing about 1 to 2 per cent of their mass for every month away from Earth. Muscles and organs also suffer in low gravity.
No astronaut has spent more than six months at a stretch on the ISS, so direct medical studies only cover relatively short-term effects. A good diet and strenuous exercise minimise the damage, but no one knows how the human body will fare on long-term missions to an asteroid, for example, or Mars.
Mice have been kept aboard the ISS for up to 91 days, during which time they were used to study a loss in blood quality called flight anaemia, and the effects of cosmic radiation on fertility.
The condition of individual astronauts is routinely studied before and after a mission, but this can only reveal so much. What's needed is research while travellers are actually in orbit.
"Previous research was a lot more limited than what we're now able to support," says Mike Roberts at the Center for the Advancement of Science in Space (CASIS), which manages science experiments on the ISS and helped fund the new scanner. "This device will enable investigators to track bone loss in real time."
Astronauts are now being trained in how to care for and handle rodents in space, and a training video on how to use the X-ray scanner will be sent to the crew before the device arrives.
But building an X-ray scanner that can operate in space is no mean feat. The machine needs to be safe to use, robust enough to survive the rattles of the launch vehicle, and straightforward to fix when something goes awry.
"Having a radiation source on board the station is something that has never been done before," says Rich Boling, a vice-president at Techshot in Greenville, Indiana. The firm spent the last two years developing the scanner, which it calls the Bone Densitometer.
The Techshot team started with a device called a dual-energy X-ray absorptiometry scanner, a common lab tool about the size of a microwave oven. Engineers went over NASA's safety guidelines and stripped out any materials that could pose a fire or health risk.
For example, the scanner's wires are normally insulated with polyvinyl chloride. This material can produce a toxic gas when heated, a serious hazard in the cramped quarters of the ISS. The space-ready scanner uses Teflon instead. And stainless steel components replaced any made of tin or zinc, as these metals can grow slender crystalline "whiskers" that might break off and cause damage.
The team redesigned the scanner to be foldable, so it can be stowed when not in use. They also made it easier to swap out certain parts, for ease of repair.
The finished machine will travel on the next cargo run by private firm SpaceX of Hawthorne, California. Due to lift off in late August, the mission will also carry SpaceX's first mammalian passengers – 20 mice and rats that will spend six months on the station in specially designed habitats. They will be used in a variety of medical experiments to assess the effects of microgravity on the body. For instance, one experiment will look at changes in the blood-brain barrier to learn more about why space travel can cause cognitive and visual problems.
The first X-ray experiments are slated to begin in December, once the animals have become accustomed to their new home and the astronauts are comfortable with their care. During a scan, they will be isolated in containers to prevent urine or faeces from floating free. To keep the animals themselves from drifting around, the X-ray tray has a sticky surface, which Techshot chief scientist Eugene Boland likens to the back of a Post-it note.
As well as providing data for future space missions, the findings might be useful back on Earth, to help people with skeletomuscular diseases, says Roberts.
For example, one study will focus on mice that have been bred to have a muscle-wasting disease tied to a particular gene. The experiment was designed by pharmaceutical firm Novartis, which will use the data to design drugs to combat the disease.
"NASA is looking for all sorts of diagnostic technology that will help with a trip to Mars," says Boling. "CASIS is looking for Earth benefits. This payload does both."
This article appeared in print under the headline "X-ray medicine blasts off to space"
Correction, 19 June 2014: When this article was first published, the final quotation was misattributed.
