High Performance Muli-Processor Support Webserver Solution
- nwclasantha
Re: High Performance Muli-Processor Support Webserver Solution
Dear Chanaka
Very nice that you have introduced Nginx web server here. It is now becoming popular due being light weight and speed. I run Apache at the moment on my dedicated servers and found that it is convenient for my requirement. Could you share your personal experience with Nginx please. What are the advantages and disadvantages over Apache? How difficult it is to setup by removing Apache on a already running server? Last time I remember that Nginx lacks virtual server support, where one IP allow multiple domains to run in a single machine. How is the current situation ? Hope your advise would help me to decide installing Nginx
You are right Neo. Nginx doesn't have Virtual Hosts since it is a Apache term. It has something called Server Blocks that use the server_name and listen directives to bind to tcp sockets. Here are some notes about those.
Two Server Blocks, Serving Static Files
A Default "Catch All" Server Block
Wildcard Subdomains in a Parent Folder
This is just a really easy way to keep adding new subdomains, or to add new domains automatically when DNS records are pointed at the server. Note that I have included FCGI here as well. If you want to just serve static files, strip out the FCGI config and change the default document to index.html. Rather than creating a new vhost.conf file for every domain, just create one of these:
http {
index index.html;
server {
server_name www.domain1.com;
access_log logs/domain1.access.log main;
root /var/www/domain1.com/htdocs;
server {
server_name www.domain2.com;
access_log logs/domain2.access.log main;
root /var/www/domain2.com/htdocs;
http {
index index.html;
server {
listen 80 default_server;
server_name _; # This is just an invalid value which will never trigger on a real hostname.
access_log logs/default.access.log main;
server_name_in_redirect off;
root /var/www/default/htdocs;
server {
# Replace this port with the right one for your requirements
listen 80 default_server; #could also be 1.2.3.4:80
# Multiple hostnames separated by spaces. Replace these as well.
server_name star.yourdomain.com *.yourdomain.com; # Alternately: _
root /PATH/TO/WEBROOT;
error_page 404 errors/404.html;
access_log logs/star.yourdomain.com.access.log;
index index.php index.html index.htm;
# static file 404's aren't logged and expires header is set to maximum age
location ~* \.(jpg|jpeg|gif|css|png|js|ico|html)$ {
access_log off;
expires max;
location ~ \.php$ {
include fastcgi_params;
fastcgi_intercept_errors on;
# By all means use a different server for the fcgi processes if you need to
fastcgi_pass 127.0.0.1:YOURFCGIPORTHERE;
location ~ /\.ht {
deny all;
- SemiconductorCat
- Major
So that, would you saying that modified server architecture like that would completely wipe out the WSO2 carbon like kernel out from the market?
Then there is absoulately no need a kernel like Carbon at all. But as a middleware WSO2 would remain as it is.
And those features like sendfile are already on the apache server. Since Apahce is maintained by lots of developers know.
