If you've ever been unable to delete a file in Windows, and can't figure out what program's using it, Unlocker is the solution. Have you ever seen these Windows error messages?
Cannot delete folder: It is being used by another person or program
Cannot delete file: Access is denied
There has been a sharing violation.
The source or destination file may be in use.
The file is in use by another program or user.
Make sure the disk is not full or write-protected and that the file is not currently in use.
Unlocker can help! Simply right-click the folder or file and select Unlocker. If the folder or file is locked, a window listing of lockers will appear. Simply click Unlock All and you are done!
As of today, the current version is 1.9.2. You may download it from here.
- It is currently Fri Jun 19, 2026 3:12 am
How to forcefully delete folders in Windows 7
Windows OS Specific Topics
