Going hypersonic: spyplane could jump to Mach 6
Post by Nipuna » Thu Nov 07, 2013 8:50 am
Coming in 2030, the SR-72 should be able to fly at Mach 6 (Image: Lockheed Martin)
We're jumping to hyperspeed. By 2030, an uncrewed spyplane will be able to fly at Mach 6 – six times the speed of sound.
Engineers at Lockheed Martin's Skunk Works lab in Palmdale, California, claim to have solved a problem that has so far prevented aircraft flying faster than Mach 3.
The SR-72 is a follow-up to the firm's piloted SR-71 Blackbird, an unarmed Mach 3 spyplane that flew cold-war reconnaissance missions until it was retired in 1998. The SR71 used a pair of powerful jet turbine engines to get to Mach 2.5. Above that speed, cones in front of each engine steered airflow away from the main jet turbine core, compressed it and injected into a chamber to be burned with fuel. This bumped its top speed up to Mach 3.
That way of steering airflow is the principle behind an engine with no moving parts called a ramjet. But ramjets don't work from a standing start, they need to be brought up to activation speed first by a regular jet or rocket engine.
And to travel at speeds defined as hypersonic, above Mach 5, a much higher speed version called a supersonic combusting ramjet - or scramjet - is needed. But a scramjet can only kick in above Mach 3, while the top speed of a jet engine is Mach 2.5.
Working with propulsion firm Aerojet Rocketdyne of Sacramento, California, and informed by research on hypersonics by NASA and DARPA in the last decade, Lockheed Martin says it has now closed the jet/scramjet gap.
The company won't reveal details, but the solution is based on a scramjet that has a fighter jet engine built in. By modifying the way it takes in air, the fighter engine can accelerate for a short time up to Mach 3, allowing it to kick into scramjet mode.
At Mach 6 – 7350 kilometres per hour - Skunk Works programme manager Brad Leland says the SR-72 could reach "any location across a continent in less than an hour".
They will have their work cut out, says Jean Dupont of MBDA, a hypersonic missile maker based in Paris, France. "Typically, temperatures in such an engine will get to well over 1000°C, much higher than the melting point of many conventional materials." So the design may require complex cooling systems that add unwanted weight, he warns.
Dennis Mendoros, a member of the London-based Royal Aeronautical Society's propulsion group, believes enough has been learned in the 15 years since the SR-71 was retired. The intervening time, he says, "has enabled researchers to benefit from advances in technology and gain a more detailed understanding of the aerodynamics and aerothermal effects when travelling at speeds up to Mach 6."
Lockheed is not the only aviation giant that is working on a a hypersonic plane. European firm EADS is developing the Mach 4 Zero Emission Hypersonic Transport (ZEHST), which it thinks could be flying by 2050.
