[media]http://www.youtube.com/watch?v=g4Phzzc8wh0[/media]
Sometimes being clumsy is useful. Instead of avoiding obstacles, a new ball-shaped flying robot exploits collisions to travel through the air, inspired by the behaviour of insects.
A prototype called GimBall created by Adrien Briod and his colleagues at the Swiss Federal Institute of Technology in Lausanne was able to fly autonomously several hundred metres through a forest despite colliding with trees.
Equipped with a compass and an altitude sensor, GimBall was able to maintain its course by keeping a constant altitude, powered by twin propellers and steered by fins. A novel gyroscopic system, made up of a double carbon fibre ring, keeps the robot upright. When it bumps into an object, a rotating, protective frame, which spins separately from the interior mechanism, absorbs the shock.
Spiky threat
It lacks positioning sensors, so the robot's trajectory isn't that precise, but it can go faster through cluttered spaces by throwing caution to the wind. It can easily handle an impact when flying at a speed of about 5 kilometres an hour but a stronger collision will break it. "Insects don't survive run-ins with car windshields either," says Briod.
Spiky objects, like branches, that can penetrate gaps in the cage are also troublesome. But the team plans to improve how the robot tackles obstacles by getting it to detect surrounding shapes. "A detection system could help it find its way into a building or circumvent objects," says Briod.
Its lightweight design is a major advantage: at barely 370 grams, it can easily stay in the air, allowing it to navigate through complex spaces. The researchers foresee it being used in difficult environments, such as in smoky areas that would throw off sensors used by typical robots.
GimBall will be presented at the iREX conference, an international robot exhibition, in Tokyo, Japan, on 5 to 9 November.
- It is currently Thu Aug 13, 2026 5:08 am
Crash-happy insect drone hits obstacles to help it fly
