dV/dt triggering of a SCR(Thyristor)
Nandika
Post by Nandika » Mon Oct 28, 2013 5:55 pm
Hello Friends,
Following quote is copied from Wikipedia(Link:http://en.wikipedia.org/wiki/Silicon-co ... _rectifier)
I have learned something about SCR(Thyristor).In normally we can apply gate threshold current(=Latching current) to turn on the SCR.
In following statement says dV/dt method for turn on a SCR.
I cant understand this method.It's unclear.
If the applied voltage increases rapidly enough, capacitive coupling may induce enough charge into the gate to trigger the device into the "on" state; this is referred to as "dv/dt triggering." This is usually prevented by limiting the rate of voltage rise across the device, perhaps by using a snubber. "dv/dt triggering" may not switch the SCR into full conduction rapidly, and the partially triggered SCR may dissipate more power than is usual, possibly harming the device.
What is this " applied voltage increases rapidly " means?
What is "capacitive coupling"?
Please anyone help me to understand this way.
Thank in advance...
SevenZero
Re: dV/dt triggering of a SCR(Thyristor)
Post by SevenZero » Tue Oct 29, 2013 11:09 pm
dv/dt Triggering of a SCR will be performed as below.
- When the device is forward biased, J1 and J3 are forward biased, J2 is reverse biased.
- Junction J2 behaves as a capacitor, due to the charges existing across the junction.
- If voltage across the device is V, the charge by Q and capacitance by C then,
ic = dQ/dt
Q = CV
ic = d(CV) / dt
= C. dV/dt + V. dC/dt
as dC/dt = 0
ic = C.dV/dt
- Therefore when the rate of change of voltage across the device becomes large, the device may turn ON, even if the voltage across the device is small.
Nandika
Post by Nandika » Wed Oct 30, 2013 6:59 pm
Thanks ZevenZero..
I understood it simply according to your answer.But,This has big theory behind.
Equation manipulation is not clear.It's my problem,I dont know calculus :(
I must learn it.
dV/dt triggering is clear. :)
SemiconductorCat
Post by SemiconductorCat » Thu Oct 31, 2013 10:58 am
Nandika wrote:Thanks ZevenZero..
I must learn it.
you mean this,
>> ic = d(CV) / dt
it's simple product rule know.
http://en.wikipedia.org/wiki/Product_rule
here there's no partial differential equations involved. IT's simply the product rule.
And SevenZero , please be kind to label what is Ic there.
however something called that 'dv/dt driver circuit' may not the easy to understand either.
Anyway I heard that you alread told that's not what you looking for.
Nandika
Post by Nandika » Fri Nov 01, 2013 7:55 pm
Thanks SemiconductorCat,
This system (dV/dt triggring) has semiconductor level explanation.I have an idea about this capacitor/capacitance which generated J2 junction.
I think,I have small idea about semiconductor level explanation.
