3D-printed objects outgrow their printers
Post by Nipuna » Fri Sep 27, 2013 8:47 am
From printer to ceiling (Image: Skylar Tibbits + Marcelo Coelho + Formlabs Inc)
[media]http://www.youtube.com/watch?v=tIgPButiHtU[/media]
3D printing may be set to change the world by letting us make all sorts of bespoke objects, but there's one little problem: the printers can only print items smaller than themselves. Until now, that is.
Skylar Tibbits at the Massachusetts Institute of Technology's Self-Assembly Lab and colleague Marcelo Coelho have come up with a way for standard 3D printers to print out large-scale objects. "It's challenging the notion that we always need a machine that's bigger than the thing it's printing," says Tibbits.
The approach, called Hyperform, converts the object to be printed into a single long chain made from interlocking links. An algorithm works out how that chain can be packed together into the smallest cube possible using a Hilbert curve – a fractal-based pattern that is the most efficient way of squeezing a single line into a small as space as possible. The resulting cube is small enough to be printed inside a standard printer.
Hand assembly
Once this cube is printed, the chain can be unravelled and assembled by hand to create the desired object. That's possible because each link in the chain has notches that allow it to bend only in a certain way. "You have to fold it by hand and click it into place," says Tibbits. Hyperform won the "The Next Idea" prize at the Ars Electronica 2013 technology festival in Linz, Austria, earlier this month.
But printing cubes made of such densely packed chains was too much for most of the consumer printers that Tibbits and his team tried. "We blew a lot of printers at first," he says. So they teamed up with Formlabs who, after a successful Kickstarter crowdfunding campaign, have just started shipping their Form 1 3D printer.
The Form 1 is capable of much higher resolution than standard consumer 3D printers. Instead of printing out layer upon layer of plastic, it uses stereolithography, in which a pool of liquid plastic is added to the base of the printer and a laser traces out the pattern required, causing the liquid plastic to cure and solidify. The technique can form layers just 25 microns thick, with details as small as 300 microns.
Hyperform has so far been used to create large structures such as a chandelier, and Tibbits sees it as being perfect for producing large 3D-printed consumer products. But the Form 1 printer uses resins which have limitations in terms of strength. "There is a range of things that are largish that we can do right away," says Tibbits. "But if you want to make large-scale furniture or buildings, there needs to be an approach to make them stronger."
4D printing
Manually clicking each link into place isn't ideal either. That's where Tibbits' other work in so-called 4D printing might help. 4D printing uses materials that are 3D-printed to produce an intermediate object which, when exposed to water, will bend and twist itself into the final structure. "You can see how Hyperform and 4D printing are pointing towards each other," he says.
Clément Moreau, CEO of French 3D printing firm Sculpteo, says projects like Hyperform are shaping the future of 3D printing. "This is yet another example of how 3D printing is more of a flexible manufacturing process than injection moulding because it constantly opens up new possibilities in terms of materials used and shapes which can be printed."
