Sunbots aim to slash the cost of solar arrays
Post by Nipuna » Sun Aug 18, 2013 1:00 am
A nightmare to keep clean (Image: Colin Anderson/Getty)
A booming solar industry could use a robotic helping hand if it's to compete with fossil fuels as a global energy provider
NEXT to the Santa Rita jail in sunny Dublin, California, a robot tends a field of solar panels. It quietly makes its way along a rail underneath them, stopping at each to adjust its tilt to face the sun.
This is SolBot, one of a handful of robots on the leading edge of a movement to use automated construction, operation and maintenance to slash the cost of solar power – critical if it is ever to compete with fossil fuels.
Solar power is booming, more than doubling to some 100 gigawatts of capacity worldwide between 2010 and 2012. Roboticists are getting in on the act, seeing opportunities to boost efficiencies in a young industry. The SolBot tending the Santa Rita field is made by QBotix, in nearby Menlo Park.
"The clever part comes in realising that the sun moves slowly across the sky, taking 40 minutes to move 10 degrees," says Wasiq Bokhari, founder and CEO of QBotix. "For a flat photovoltaic plate, you can adjust it once every 45 minutes and keep maximum efficiency."
This means one robot can tend about 1200 solar panels – roughly 300 kilowatts – on its own. SolBot's sensors pinpoint the sun's position to within 1 degree and it adjusts each panel accordingly. Having a robot do this avoids the need for expensive tracking structures to keep the panels moving throughout the day.
Matthew Muniz, who is the energy programme manager for Alameda County, says the presence of the robots makes the solar field about 20 per cent more efficient than the roof-mounted solar panels that also supply the jail's microgrid.
Meanwhile, Alion Energy, based in Richmond, California, uses robotics to bring down the cost of building and maintaining solar arrays.
The company uses concrete as the base for its set-up, as well as the guide rail for an automated cleaning robot. Once the base has been laid, a custom-built robot called Rover trundles over it, gluing rows of panels in place. At the end of the row, a human worker loads the robot with the next set of panels, and it crawls to the next concrete baseline. Once the panels are installed, a cleaning robot called Spot keeps them in working order.
Alion is due to start building its first commercial solar plant – a 3-megawatt array in California – by the end of the year, says spokesman Jesse Atkinson.
Spot could be especially useful in the Middle East and western China, Atkinson says, as most of the proposed solar farms there are in desert areas where dust can rob panels of as much as 40 per cent of their energy potential, if they are not cleaned frequently. The company is working on a pilot plant at the King Abdullah University of Science and Technology in Thuwal, Saudi Arabia, as well as with the country's national energy company Aramco. "We can do it at a quarter of the cost [of hiring cleaners], and with a 90-per-cent reduction in water use," says Atkinson.
For solar robots to really take off, standardised construction is essential, say Atkinson and Bokhari. Atkinson compares potential advances and simplification in solar power provision to those made in car manufacture: "Dashboards used to be 40 to 50 parts, manually put together. Then they started using plastics and were able to mould one big plastic form. They went from 40 parts to three."
This article appeared in print under the headline "Rise of the sunbots"
AngeloSullivan
Re: Sunbots aim to slash the cost of solar arrays
Post by AngeloSullivan » Sat Nov 16, 2013 3:32 pm
Really awesome news.. Prices of these solar panels must come down so that common man could use them and our dependency on fossil fuel comes down..
