Beyond 3D printing: The all-in-one factory
Post by Nipuna » Fri Aug 16, 2013 10:09 am
More options than a 3D printer (Image: Mebotics)
3D PRINTERS are about to get an upgrade. The latest not only prints objects, it can cut and etch them too, making it far more versatile.
The Microfactory is a portable, self-contained machine just a little larger than an average desktop 3D printer. As well as the standard printing equipment, it contains a series of milling and printing heads that can cut and etch plastics, hardwoods and some light metals. Its creator, Massachusetts-based start-up Mebotics, describes it as the "world's first machine shop in a box".
"If you had a database of parts for your Humvee you could connect the machine to a Wi-Fi hotspot, download the part you need from a directory and make it on the fly out in the middle of nowhere," says Jeremy Fryer-Biggs, one of four co-founders of Mebotics. All met as part of the "maker" movement – in which people get together to create DIY technology.
The machine can be loaded with up to four different coloured plastics or two different materials. Its internet connection allows you to remotely start the machine and monitor its progress, and download a ready-made design from the internet to manufacture directly. Alternatively the user can design the part they want using a standard software package.
The Microfactory then translates the code into three-dimensional positions for the milling heads and builds the part step-by-step. Embedded in each design is code that tells the machine when to switch milling bits or change printhead and colour. The controls are so precise that even microchips can be etched inside the box, which is designed to be quieter than other 3D printers.
Microfactory not only lets users make products out of printable materials, like plastics, but also from wood and metal, which can only be machined. "The key issue is this integration of machining and 3D printing," says Phil Reeves at 3D printing firm Econolyst. "After four or five years of the maker revolution I think everyone's come to realise that you can't make everything in these machines."
The Mebotics team have been testing their creation by making objects like keyrings. Meanwhile, the maker of Magnet Comic, a comic-strip desk toy and the result of a Kickstarter project, has been using the Microfactory to meet demand.
Sylvain Preumont, founder and CEO of 3D-printing outlet iMakr, is impressed. He thinks consumers will love multitasking machines and says his site My Mini Factory, where people can download 3D designs to print at home, will soon be hosting files for printers like Microfactory.
The device has real potential for on-the-spot manufacturing, says Reeves. "It has the capability to cut a key, or to re-manufacture something. It has all those capabilities and that is exciting."
The Mebotics team hopes to commercialise the Microfactory by raising over $1 million through Kickstarter. Fryer-Biggs thinks other inventors will definitely be interested. "It's the machine I always wanted," he says.
This article appeared in print under the headline "The all-in-one factory"
Re: Beyond 3D printing: The all-in-one factory
Post by Neo » Fri Aug 16, 2013 10:27 am
The MakerBot is the best 3D printer I know in the field. Have a look.
[media]http://www.youtube.com/watch?v=f8jx69iVl4c[/media]
Post by Nipuna » Fri Aug 16, 2013 12:16 pm
Cool :)
