Lines on the face help pick out the twin who dunnit
Post by Nipuna » Mon Jul 29, 2013 1:04 am
Spot the difference (Image: Lisa Wiltse/Corbis)
"MY TWIN did it" might seem like the perfect defence, but it won't work for much longer. A computer program that can pick out small differences in identical twins' facial features as they age can distinguish them 90 per cent of the time.
The identical DNA, appearance and voices of twins can make life difficult for forensic investigators. In Canada last week, for instance, identical twins who had broken into a house together were convicted of the same charges, since police couldn't determine which twin had committed an assault or used a weapon.
Although there can be some very small differences in DNA between identical twins (see "Picking the perp"), developing tests to spot these changes is too expensive to be practical. Instead, the US Federal Bureau of Investigation funds a research project at Twins Days Festival in Twinsburg, Ohio, where researchers can test out various biometric technologies to distinguish the pairs.
Marios Savvides of Carnegie Mellon University in Pittsburgh, Pennsylvania, believes the key to distinguishing twins is to look at their behaviour, which is reflected in the face. "When you have an expression or smile, that's when your brain comes into play and you exhibit asymmetry," he says.
Savvides collected photos of twins from a Twins Days event and found that in a side-by-side comparison, even twins with neutral facial expressions showed asymmetry. These asymmetries became easier to spot when Savvides's group cut digital photos of both twins' faces in half and turned each side into a mirror image of itself.
Next, they looked at how faces change over time. As people age, habits such as smoking plus weight change and common facial expressions alter the appearance of the face. Twins are no different, Savvides says, making older pairs of twins easier to distinguish than younger twins.
Savvides's group had been developing an algorithm that determines the age of a person in a photo by examining facial lines and textures in nine places around the eyes and upper lip. Even young people have the beginnings of such lines, he says.
They have now adapted this algorithm to highlight the differences in age lines between identical twins. When tested on photos of 638 pairs of identical twins, the program was able to correctly distinguish between the twins 90 per cent of the time. If a security camera at a crime scene captures the face of a twin, such a computer algorithm should be able to match it with the correct twin, says Savvides. The research has been submitted to IEEE Transactions on Image Processing.
Kevin Bowyer of the University of Notre Dame in Indiana, whose research group created the data set used by Savvides, says techniques to distinguish twins could help train forensic examiners in facial recognition. Because a twin-detecting algorithm needs to be precise, it could also lead to algorithms that are more accurate for all faces, he says.
This article appeared in print under the headline "Double trouble"
Picking the perp
Face recognition techniques can't solve all twin identification problems (see main story). Although he was the main suspect in his identical twin's death in 2007, jurors couldn't reach a verdict in the trial of Wael Ali last year. Because their DNA is identical, any DNA evidence at the scene was deemed useless. Similarly, police in France are struggling to identify which of two brothers accused of multiple rapes to prosecute.
But there's still a chance their DNA could help. In 2008, geneticists at the University of Alabama discovered that identical twins sometimes have different numbers of copies of a gene (American Journal of Human Genetics, doi.org/dbw83g). And in 2005 Mario Fraga of the Spanish National Cancer Research Center found that small epigenetic changes mean twins' DNA is not always identical (PNAS, doi.org/bc2z9z).
Standard DNA tests wouldn't pick up either of these changes, however, making them expensive and time-consuming to check. Niall Firth
