Inflatable arm will soften up anti-bomb robot
Post by Nipuna » Fri Jun 28, 2013 12:25 pm
Pump those muscles
Pump those muscles
It looks like a cross between a miniature tank and a toy elephant – but it could be the future of military robotics. Last week iRobot, based in Bedford, Massachusetts, applied for a US patent for an inflatable arm that could make military robots lighter, cheaper, more agile and safer.
In addition to making the robot vacuum cleaner, Roomba, iRobot is maker of PackBot, a tracked robot that that features an articulated arm designed for defusing improvised explosive devices and for demining.
Two of the machines played a role in the aftermath of the disaster at the Fukushima Daiichi nuclear power plant in Japan in 2011, helping to clear debris and aiding imaging of shattered reactor buildings.
The new device is a riff on the PackBot, but with its metal arm replaced by a lightweight rubbery arm that can be pumped up to the stiffness required. Pairs of artificial muscles manipulate the arm and its grippers.
Neatly stowed
In a US patent application 2013/0152724, filed on 20 June, the firm says the PackBot's weight and long metal arm make it cumbersome to transport. The patent calls for replacing the metal arm with a lightweight rubbery membrane that encloses inflatable arm segments, which can be folded into the robot's body for storage.
When deployed in the field, the flaccid arm's jointed, rotatable segments are pumped up and tuned to the stiffness required for the task by an intelligent pressure-control system. The arm and grippers are moved by pairs of artificial muscles called McKibben actuators – essentially long pneumatic bladders that act in opposition to each other, like human biceps and triceps.
The challenge for iRobot will be in making the motors needed to drive the rotation of joints and air compressors light enough to make this switch to inflatable robotics worthwhile. If it can, the firm claims the new robot will be much safer than the current iteration. For example, the patent filing notes that the soft, pliant arms should end harmful collisions with humans and other fragile objects.
