Gadgets should be sleek and powerful but must not overheat, and that's a big problem for small circuitry. At the nano-scale, weird quantum effects come into play, and uncontrollable temperature fluctuations become seriously limiting.
Now physicists have built a thermometer that can measure the slightest temperature change in circuits the size of a single molecule. The device could help realise the dream of electronics made from graphene, carbon nanotubes and other super-small materials.
The exponential decrease in transistor size seen to date – often referred to as Moore's law – suggests that in one to two decades we should see nano-scale transistors, says Pramod Reddy at the University of Michigan in Ann Arbor. Without an appropriate thermometer to see how such transistors shed heat, experiments on nanomaterials cannot test theoretical predictions. That makes it hard to control for overheating, which can cause circuits to fail.
Energy dump
In the electrical currents that flow in the microcircuits of today's gadgets, the electrons behave like particles and follow classical, predictable laws of heat transfer. But on the molecular scale, electrons are essentially waves, and their behaviour is governed by quantum probability, which makes predicting their behaviour &ndash and thus where they will release heat – much more tricky.
Juan Carlos Cuevas at the Autonomous University of Madrid in Spain and his colleagues modified a scanning tunnelling microscope – which allows the manipulation and imaging of atoms – to trap a ring of benzene between the probing tip of the microscope and a flat gold surface.
Passing a current through tiny electrodes attached to each end of the benzene molecule sent electrons coursing through it, generating heat. The probe then measured the temperature change in each electrode. Differences between the measurements indicated where the molecule was shedding heat.
Super-shrink me
The team repeated the experiment for benzene molecules with different chemical groups attached. They found that heat dissipated at different places in each variation of the molecule. The results helped the team develop a new quantum theory of heat dissipation based on molecular structure.
"The electronic structure of a molecule determines the quantum probability for electrons to flow through the nano-device," says Reddy. It is this probability that determines where electrons dump their excess energy. "This means that one can control at will in which electrode the heat is released by simply using the proper molecule." The research could help guide selection of materials for use in future molecular-size transistors.
Li Shi of the University of Texas at Austin, who was not involved in the work, says that Reddy's team has "pushed the measurement capability to approach the limits in spatial and temperature resolutions". This is crucial, because as transistors get ever smaller, we need to know in the finest detail how they heat up – so we can help them keep their cool.
- It is currently Sun Sep 27, 2026 8:05 pm
First glimpse of a single molecule dumping heat
