Ultra elevator takes you higher with carbon-fibre tape
Post by Nipuna » Wed Jun 12, 2013 8:25 am
Your life will depend on it (Image: Kone)
Going up? Elevators can now carry people to the top of a kilometre-high skyscraper in a single run. The key is the development of a super-light and super-strong lift-hoisting cable. The sheer weight of the steel cable that hoists today's elevators has prevented them going any higher than 500 metres in one go.
That means, for instance, that people in Dubai's 828-metre-high Burj Khalifa tower, currently the world's tallest building, have to switch lifts to go above the 500-metre mark. But lifts in the nascent Kingdom Tower in Jeddah, Saudi Arabia – due to top out above 1 kilometre in 2019 – could use the new technology to zoom to the top in one go.
With at least 20 buildings more than 500 metres high on architects' drawing boards around the world, and more expected as megacities proliferate, lift maker Kone Corporation of Espoo, Finland, has been engineering ways to move people up and down them in more convenient and less energy-intensive ways. In London yesterday it revealed its solution: UltraRope.
Instead of interwound steel hawsers, Kone's hoisting line comprises four carbon-fibre tapes sealed in transparent plastic about 4 centimetres wide and 4 millimetres thick. It's more like a belt than a rope and looks like a school ruler shot through with magnetic tapes.
UltraRope beats steel for tensile strength but weighs only one-seventh as much. "That's a tremendous amount of steel you won't have to move around the building," says Kone's head of technology, Johannes de Jong. "And it will last longer than steel too."
Test of years
The material has been under test in a 333-metre-deep mineshaft in Lohja, Finland, since 2004. That may seem a long time, but because lives will depend on UltraRope, de Jong and his colleagues had to ensure it ages safely. As well as repeatedly heating and cooling it to tropical and arctic temperatures to accelerate the ageing process, they also tested its fire resistance and even the effect that tools dropped down a lift shaft could have on it. It has now passed all European Union and US certification tests, de Jong says.
UltraRope will also save energy. Simulating its use in a 640-metre-high building, Kone found that the elevator used 11 per cent less electrical power than a steel-cabled version.
Kone's main rival, Otis Elevator of Farmington, Connecticut, is also looking at carbon fibre for use in future ultra-tall buildings. However, the US company is thinking of using the material to strengthen steel cables.
"UltraRope is one of the biggest breakthroughs since the advent of the [Otis] safety elevator 150 years ago," says Antony Wood, executive director of the Council on Tall Buildings and Urban Habitat in Chicago.
"The biggest limiting factor in building higher until now has been the steel rope weight – and we have reached the limit of that technology at 500 metres."
With 200,000 people moving to, or being born into, urbanised environments every day, according to the UN, Wood sees building ever upwards in megacities as a valid – though difficult – answer to housing people. "Where will all those people go? Horizontally expanding suburbs? If they do that, we're all screwed."
