QUANTUM clones are making a noise, and banks and governments better listen if they don't want to be hacked.
A device that makes rough copies of intercepted photons can allow an eavesdropper to hide unnoticed in the background noise present in quantum encryption keys, which banks, companies and governments use to send confidential information. But there is a way to monitor the noise to uncover an attack.
Quantum cryptography generates theoretically unbreakable encryption keys from photons orientated in one of two directions, corresponding to a 0 or a 1. The resulting sequence of digits can encode a message, which is then sent via conventional means, such as fibre-optic cables.
In theory, any attempt by a third party to intercept the key will introduce noticeable errors into the transmission. According to the rules of quantum mechanics, the photons will travel in a superposition of all possible orientations, and will only collapse into the ones desired by the sender when observed by the receiver. An eavesdropper would cause the photons to collapse in the wrong way, sending on an error-ridden message and raising alarms.
But in practice there will always be some background noise in the messages – an error rate of 11 to 16.7 per cent is considered acceptable, depending on the circumstances. Now Karol Bartkiewicz of Palacký University in Olomouc, Czech Republic, and colleagues have discovered that a hacker can hide in this noise.
The attack relies on a device called a quantum cloner, which creates copies of the photons. Although the clones aren't perfect, they are good enough to keep the error rate low. The attacker then keeps one copy for themselves and sends the other to the original recipient. Once the transmission is complete, the hacker can decrypt the message.
Bartkiewicz's team carried out an attack in the lab and intercepted the key while introducing an error rate of around 18.5 per cent, meaning that anyone not paying close attention to noise on their quantum line could be duped (Physical Review Letters, doi.org/mck).
"You have to be careful about the error rate," says Bartkiewicz. "If you monitor that, quantum cryptography is still safe."
This article appeared in print under the headline "Quantum codes open to attack of the clones"
- It is currently Sun Sep 27, 2026 8:41 pm
Quantum clones let hackers hide in background noise
