how to create rounded form using windows APIs?
Ta
						Create rounded form
Re: Create rounded form
Private Declare Function GetWindowRect Lib "user32" (ByVal hWnd As Long, lpRect As RECT) As Long
Private Declare Function SetWindowRgn Lib "user32" (ByVal hWnd As Long, ByVal hRgn As Long, ByVal bRedraw As Long) As Long
Private Declare Function CreateRoundRectRgn Lib "gdi32" (ByVal X1 As Long, _
    ByVal Y1 As Long, ByVal X2 As Long, ByVal Y2 As Long, ByVal X3 As Long, _
    ByVal Y3 As Long) As Long
Private Declare Function DeleteObject Lib "gdi32" (ByVal hObject As Long) As Long
Private Type RECT
    Left As Long
    Top As Long
    Right As Long
    Bottom As Long
End Type
Private Sub Form_Load()
    Dim lpRect As RECT
    Dim W As Long, H As Long
    Dim hRgn As Long
    ' get the bounding rectangle's size
    GetWindowRect hWnd, lpRect
    W = lpRect.Right - lpRect.Left
    H = lpRect.Bottom - lpRect.Top
    hRgn = CreateRoundRectRgn(0, 0, W, H, 20, 20)
    ' trim the window to the region
    SetWindowRgn hWnd, hRgn, True
    DeleteObject hRgn
End Sub
