How a surgeon installs seizure sensors inside a skull
Post by Nipuna » Fri Mar 29, 2013 9:54 am
Next time he has a seizure, electrodes will show where (Image: Anil Ananthaswamy)
Our reporter watches a brain surgeon implanting electrodes inside the skull of a person with epilepsy to pinpoint where his seizures start
A YOUNG man lies unconscious on the table, his head clamped firmly in place. His eyes are closed. The hair over his left temple has been shaved.
I'm in the operating room at University Hospital Zurich in Switzerland with neurologist Thomas Grunwald, who has diagnosed 22-year-old Jeremy Künzler with drug-resistant temporal lobe epilepsy. His symptoms during fits suggest that the seizures begin in the left temporal lobe. Often, this condition can only be treated by surgically removing the errant brain tissue. Unfortunately, brain scans have revealed nothing that would point to the source of Künzler's seizures – no obvious tumour, scar or lesion.
In ordinary circumstances, Künzler would have to undergo exploratory brain surgery. But instead of this drastic operation, Grunwald is pioneering a technique to pinpoint the problem area. He has asked neurosurgeon Niklaus Krayenbühl to implant electrodes inside Künzler's skull: a grid electrode over his left temporal lobe, and two strip electrodes beneath the left and right lobes, used to monitor activity bilaterally in the hippocampi and amygdalae. Once they are in place, Grunwald will record brain signals in real time during seizures and use the information to try to identify the epileptogenic tissue.
It's my first time inside an operating room. I'm anxious, as I have been told not to touch a thing for fear of contamination, especially the giant surgical microscope covered in clear, sterile plastic. "The nurses are very strict," says Grunwald. "If you touch this, even with your head, they get really angry."
Krayenbühl swiftly cuts through the scalp and the temporal muscle, cauterising and clamping the edges with plastic clips to prevent bleeding, and peels the tissue back to reveal the skull bone. He drills two holes in it and saws out a circular piece. The sounds remind me of the dentist. Wisps of smoke rise from the heat of metal against bone. The surgeon removes the bone flap, exposing the meninges – the layers of membrane that envelop the brain. To avoid any chance of infection, the nurse helps Krayenbühl slip on a fresh pair of gloves.
He then parts the first, thick layer of the meninges, the dura mater. Below it is the arachnoid layer, beneath which flows the cerebrospinal fluid bathing the brain. Krayenbühl makes tiny cuts in the arachnoid, to let the CSF ooze out and relieve the pressure. "Otherwise the brain will pop out like a mushroom," he says.
Krayenbühl is working through the microscope and what he's seeing is projected onto a large screen. The brain tissue is clearly visible: a whitish convoluted surface suffused with blood vessels. Krayenbühl works quickly to slip the electrodes, just 0.7 millimetres thick, between the dura mater and the arachnoid. Once he's done, he works in reverse, sewing up the dura mater, reattaching the bone with titanium clips, suturing the muscle and scalp. The electrode cables, which exit the skull through the two holes, are drawn out through tiny cuts in the scalp.
The surgical staff then turn the patient over and start working on the right side of the brain.
Two days later, I visit Künzler, recovering at the Swiss Epilepsy Centre across town. He has two black eyes from a surgery-induced haematoma, but they still have a twinkle. His head is heavily bandaged. Künzler's English is limited, so Grunwald translates.
Though Künzler's anti-epileptic medication barely has an effect on the frequency of his seizures, it has been reduced to let more occur. "If we are lucky, then we'll get seizures maybe tonight or tomorrow," Grunwald tells me. Künzler laughs. He knows enough English to get what Grunwald is saying. I ask him if he's afraid of the seizures. "I'm not afraid, as long as it'll help me," says Künzler.
It is Grunwald's job to analyse the intracranial EEG signals and locate the source of the seizures. There is no automated process to help him sift through the data, just his own skill and experience. "If you record 24 hours of EEG, then you have to look at 24 hours of EEG," says Grunwald. "Every second of it." He hopes they'll show that Künzler's seizures are in the left temporal lobe and far away from the Wernicke's area that is involved in language, which he cannot remove.
This article appeared in print under the headline "Inside the brain, searching for seizures"
