Cellphone sniffer hunts down illicit prison calls
Post by Nipuna » Thu Mar 14, 2013 8:01 am
No phones for them (Image: Sandy Huffaker/Corbis)
Contraband cellphones are a massive problem in prisons?– now there’s a way to see who’s using one
SHOT six times in a "hit" allegedly planned by prisoners, Robert Johnson knew just who to blame: the cellphone service providers that failed to block calls made inside the jail. Last week, he announced that he plans to sue 20 of these companies.
Yet it is virtually impossible to stop cellphones being used inside prisons, often for criminal purposes. But a way of pinpointing exactly where a call is coming from could help clamp down on the practice.
Johnson, a guard at Lee Correctional Institution in Bishopville, South Carolina, was in charge of efforts to keep contraband out of the facility. He was shot at his home in March 2010, and believes the attack was organised by a prisoner. He says that had local mobile networks chosen to, they could have jammed calls from inside the jail. He is seeking unspecified damages in a case his attorney hopes will push networks to deal with the problem of illicit cellphone use in prison.
But it's a tough problem to crack, because at the moment there is no way of blocking individual signals. The only option is to jam all signals at one cellphone tower, which would also disrupt calls between guards and by people living in the neighbourhood – including those to the emergency services. Setting up dedicated cellphone towers for the sole use of prison staff is an option but they are expensive– costing more than $1 million per prison.
And people will always find ways to get phones into prisons, for example, by smuggling them hidden in body cavities, or by bribing corrupt officials.
A team at Intelligent Automation Inc (IAI) of Rockville, Maryland, has now found a way to pinpoint the prison cell that a call is coming from. This has not been done before, says IAI engineer Benjamin Lonske, because the signals in a prison wing are just too messy to analyse. "Inside, there are a lot of radio waves from phones bouncing off the cell doors, walls and stairs," he says. This foils attempts to triangulate the source of the signal.
IAI's answer is simple: analyse the phone signals from immediately outside the prison walls instead – where the signals are unaffected by radio echoes.
By installing four 5-centimetre antennas at the corners of the building of interest, IAI has managed to locate a phone in use to within 50 centimetres, the team says.
The antennas are connected to a customised signal processing computer that measures the time it takes for a digital phone signal to reach each antenna. The sub-nanosecond differences allow the software to triangulate, from the best three signals, which cell the phone is in. You can then send in guards with sniffer dogs to search for it.
"We can detect phone activity, whether it is voice, text or data, in the monitored area, and map the cellphone location," says Eric van Doorn of IAI. The research was funded by the US government's National Institute of Justice.
The system currently works for the communication technology standard used by most cellphones in the US. IAI is working on modifying it to cater for other popular formats that use different digital coding and frequency bands.
Full field tests at a state prison in Lawrenceville, Virginia, are set for later this year, van Doorn says.
This article appeared in print under the headline "I'm calling from my cell..."
Time to pay for that call
Stopping prisoners using illicit cellphones could be as easy as installing in-cell payphones.
"The question is: why are people using cellphones in prison?" says Andrew Neilson of the Howard League for Penal Reform in London.
Having to queue for calls on non-private payphones increases tension on prison wings and drives illicit cellphone acquisition. In-cell payphones are the answer, says Neilson – and the UK's chief inspector of prisons agrees. Already used in some privately run UK prisons, they boost prisoner contact with their families, and they can be monitored. "Better family contact is established as a good thing that prevents people re-offending," Neilson says.
