My Simple Random Password Generator
Java programming topics
Post by Nipuna » Sat Mar 09, 2013 1:19 pm
Hi
After a long time I've wrote a Java program for fun :)
I couldn't study Java for more than 6 months now because of BIT studies and etc..
This time I didn't use any IDEs just used Notepad++ and Command Prompt :)
Here is a screenshot of my program to make my this post look good :D
Anyway here you go. I also made a .Jar file too so everyone can download and run without compiling. :)
RandomPass.java
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.FlowLayout;
import javax.swing.*;
import java.awt.Toolkit;
import java.awt.datatransfer.Clipboard;
import java.awt.datatransfer.StringSelection;
public class RandomPass extends JFrame{
	JButton generate = new JButton("Generate Password");
	JButton copy = new JButton("Copy Password");
	JTextField output = new JTextField("No Password",10);
	public RandomPass(){
		super("Random Password generator");
		JFrame frame = new JFrame();
		frame.setSize(300,110);
		frame.setVisible(true);
		frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		frame.setLayout(new FlowLayout());
		frame.add(output);
		frame.add(generate);
		frame.add(copy);
		generate.addActionListener(new Handler());
		copy.addActionListener(new Handler());
	public static void main(String args[]){
		RandomPass RP = new RandomPass();
	private class Handler implements ActionListener{
		PassGen passgen = new PassGen();
		public void actionPerformed(ActionEvent e){
			if(e.getSource() == generate){
				output.setText(passgen.getRandomPass());
			}else{
				String str = output.getText();
				Toolkit toolkit = Toolkit.getDefaultToolkit();
				Clipboard clipboard = toolkit.getSystemClipboard();
				StringSelection strSel = new StringSelection(str);
				clipboard.setContents(strSel, null);
				JOptionPane.showMessageDialog(null,"Copied to Clipboard");
PassGen.java
import java.util.Random;
public class PassGen{ //This class generates the password
	Random randomNo = new Random();
	private int intGenerate(){ //This generates numbers
		return randomNo.nextInt(1000000);
	private String alphabetGenerate(){ //This generates letters
		String alphabet ="abcdefghijklmnopqrstuvwxyz";
		String leters =
		""+alphabet.charAt(randomNo.nextInt(26))
		+""+alphabet.charAt(randomNo.nextInt(26))
		+""+alphabet.charAt(randomNo.nextInt(26));
		return leters;
	// This Randomize the numbers and the letters and returns the new randomized password
	public String getRandomPass(){
		int part1 = intGenerate();
		String part2 = alphabetGenerate();
		if(randomNo.nextBoolean()){
			return "" + part1 + part2;
		}else{
			return part2+part1;
Here is the .jar file (Since .jar extension isn't allowed, I've added it into a .zip file ;) Extract it and use it :) )
RandomPass.zip
(2.89 KiB) Downloaded 986 times
Hope you'll get any use of it :)
Re: My Simple Random Password Generator
Post by Neo » Mon Mar 11, 2013 8:30 am
Nice !
Post by Nipuna » Mon Mar 11, 2013 12:58 pm
desper
Post by desper » Sat May 04, 2013 5:02 pm
Good one men.
Return to “Java Programming”
