Boo! Robots learn to jump like frightened mammals
Post by Nipuna » Wed Oct 24, 2012 9:01 am
Eek! I'm outta here (Image: SuperStock)
ROBOTS developed in the safety of a laboratory can be too slow to react to the dangers of the real world. But software inspired by biology promises to give robots the equivalent of the mammalian amygdala, a part of the brain that responds quickly to threats.
STARTLE, developed by Mike Hook and colleagues at Roke Manor Research of Romsey in Hampshire, UK, employs an artificial neural network to look out for abnormal or inconsistent data. Once it has been taught what is out of the ordinary, it can recognise dangers in the environment.
For instance, from data fed by a robotic vehicle's on-board sensors, STARTLE could notice a pothole and pass a warning to the vehicle's control system to focus more computing resources on that part of the road.
"If it sees something anomalous then investigative processing is cued; this allows us to use computationally expensive algorithms only when needed for assessing possible threats, rather than responding equally to everything," says Hook.
This design mimics the amygdala, which provides a rapid response to threats. The amygdala helps small animals to deal with complex, fast-changing surroundings, allowing them to ignore most sensory stimuli. "The key is that it's for spotting anomalous conditions," says Hook, "not routine ones."
STARTLE has been tested in both vehicle navigation and robot health monitoring. In the latter, it can be trained to respond to danger signs, such as sudden changes in battery power or temperature. It has also been tested in computer networks, as a way to detect security threats, having been trained to identify the pattern of activity associated with an attack.
"A robot amygdala network could be useful," says neuroscientist Keith Kendrick of the University of Electronic Science and Technology of China in Chengdu. "Such a low-resolution analysis will sometimes make mistakes, and you will avoid something needlessly." But a slower, high-resolution analysis is also carried out, he says, which can override the mistakes.
Hooks says that STARTLE could be useful for any robots in complex environments. For example, a robot vehicle would be able to spot other drivers behaving erratically, a major challenge for conventional computing.
