Cassette tapes are the future of big data storage
Post by Nipuna » Tue Oct 23, 2012 11:11 am
Like a mixtape, only bigger (Image: Saturno Dona/ Alamy)
THE cassette tape is about to make a comeback, in a big way. From the updates posted by Facebook's 1 billion users to the medical images shared by healthcare organisations worldwide and the rise of high-definition video streaming, the need for something to store huge tranches of data is greater than ever. And while hard drives have traditionally been the workhorse of large storage operations, a new wave of ultra-dense tape drives that pack in information at much higher densities, while using less energy, is set to replace them.
Researchers at Fuji Film in Japan and IBM in Zurich, Switzerland, have already built prototypes that can store 35 terabytes of data - or about 35 million books' worth of information - on a cartridge that measures just 10 centimetres by 10 cm by 2 cm. This is achieved using magnetic tape coated in particles of barium ferrite.
But the real debut for this technology is likely to be the Square Kilometre Array (SKA), the world's largest radio telescope, whose thousands of antennas will be strewn across the southern hemisphere (New Scientist, 2 June, p 4). Once it's up and running in 2024, the SKA is expected to pump out 1 petabyte (1 million gigabytes) of compressed data per day.
Current projections by the trade body Information Storage Industry Consortium show that although hard drives will be able to store 3 terabytes a piece in a decade's time, that still amounts to at least 120,000 drives a year.
That annual archive growth would swamp an experiment that is expected to last decades, says Evangelos Eleftheriou of IBM, who is part of a team working to build tapes for the SKA. By the time the telescope comes online, he and colleagues expect to be able to store 100 terabytes on a cartridge of a similar size to their prototype, by shrinking the width of the recording tracks and using more accurate systems for positioning the read-write heads used to access them.
Using tapes should cut down drastically on energy use, too. Data centres based on disc drive arrays use over 200 times more power than would a tape library of similar size, according to a 2010 study by The Clipper Group, a technology consultancy based in Rye, New Hampshire. That's because disc drives in large arrays tend to remain powered-up, so their platters spin continuously, in case data is required, says Jon Hiles of Spectra Logic, a digital archiving firm in Boulder, Colorado. But tape drives only use power when they are being read or recorded on, he says.
The downside of tapes is that they are slower to access than hard discs because they have to be fetched by a robotic mechanism, inserted in a reader and spooled to the right point. But the Linear Tape File System, which is being developed, expedites this process to make it comparable to disc drives, Eleftheriou says.
As storage needs skyrocket, hard drives won't be able to keep up and keep power down, Eleftheriou says. Density improvements in hard drives are facing physical limits that mean they can only add more power-munching platters. "It's time to take advantage of the low power and low cost of tape," he says.
Re: Cassette tapes are the future of big data storage
Post by Neo » Fri Oct 26, 2012 8:29 am
The biggest two problems I have experienced myself on those good old days with cassettes were fungus and reduction of magnetic power on the tapes. DAT tapes are still knows to be used for highest quality real-time recording, but I'm not sure those two issues I practically experienced has overcome with time.
Post by Nipuna » Fri Oct 26, 2012 8:37 am
Hi Neo
Good to see you are replying,
By the way, Personally I don't like future computers and etc.. to use cassettes, I feel they are old and new things like CD,DVD,BR and flash drives must be involved except using old ones :D
It's just my opinion :)
Post by Neo » Fri Oct 26, 2012 8:56 am
You know what Nipuna. I used cassettes with computers :)
It was my first machine called Sinclair Spectrum (Made in England).
Mine exactly looked as follows:
I had to use my cassette recorder to get my programs recorded and then had playback to get them back.
If you go to this article, you will see that there was a later version of it with in-built cassette recorder. Later on they moved to in-built floppy disk. But finally the Sinclair company had closed. The owner of the company had given a knight name and called "Sir Sinclair" for his great inventions.
So the magnetic cassettes on computers is not a new thing. However, as you said, I can't even move back to floppy disks. I have experienced the pain with them and the huge relief with today's technology.
Post by Nipuna » Fri Oct 26, 2012 9:00 am
Wow :o
You have said about your computer to me before, Because of it you are with us today (of course and your Dad) ;)
But I didn't know you used cassette tapes as the storage medium of your computer. :o
I used them to listen to songs and watch movies when I was little :D
Post by Neo » Fri Oct 26, 2012 9:22 am
You would exactly see this screen while loading from a cassette to Sinclair. As the video says, indeed this is an unforgettable sound ;)
[media]https://www.youtube.com/watch?v=8fYFsBRVC8Y[/media]
It took a long time to load a program using a cassettes. With a little problem, it is required to playback from the beginning. You can feel the pain. However it was fun those days ;)
On the video notice "PSION Computers". They are the guys who made Symbion OS later on.
http://en.wikipedia.org/wiki/Psion
Another video
[media]http://vimeo.com/24286572[/media]
Lot of history. Anyway, finally you know loading/saving data using cassettes in not new to computers.
Post by Nipuna » Fri Oct 26, 2012 9:39 am
Yeah lot of history
Yes I know it's not new for computers. I've learned and have heard about them so many times :)
Post by Rksk » Fri Oct 26, 2012 1:37 pm
But if a tape can store large amount of data, it's useful for backing-up. (but magnets can destory data :-))
Post by Nipuna » Sat Oct 27, 2012 11:42 am
Yeah we will see ;)
