Tutorial on AT Commands for GSM/GPRS with microcontrollers
SevenZero
Post by SevenZero » Wed Sep 26, 2012 3:30 am
AT commands are used to control MODEMs. AT is the abbreviation for Attention. These commands come from Hayes commands that were used by the Hayes smart modems. The Hayes commands started with AT to indicate the attention from the MODEM. The dial up and wireless MODEMs (devices that involve machine to machine communication) need AT commands to interact with a computer. These include the Hayes command set as a subset, along with other extended AT commands.
If you use a GSM/GPRS module such as SIM900, you will need to use these commands.
AT commands with a GSM/GPRS MODEM or mobile phone can be used to access following information and services:
Information and configuration pertaining to mobile device or MODEM and SIM card.
  1. SMS services
  2. MMS services
  3. Fax services
  4. Data and Voice link over mobile network
The Hayes subset commands are called the basic commands and the commands specific to a GSM network are called extended AT commands.
Types of AT Commands
There are four types of AT commands as below.
  1. Test commands - used to check whether a command is supported or not by the MODEM.
    SYNTAX: AT<command name>=?
    For example: ATD=?
  2. Read command - used to get mobile phone or MODEM settings for an operation.
    SYNTAX: AT<command name>?
    For example: AT+CBC?
  3. Set commands - used to modify mobile phone or MODEM settings for an operation.
    SYNTAX: AT<command name>=value1, value2, …, valueN
    Some values in set commands can be optional.
    For example: AT+CSCA=”+9876543210”, 120
  4. Execution commands - used to carry out an operation.
    SYNTAX: AT<command name>=parameter1, parameter2, …, parameterN
    The read commands are not available to get value of last parameter assigned in execution commands because parameters of execution commands are not stored.
    For example: AT+CMSS=1,”+ 9876543210”, 120
Commonly used AT commands in detail
Explanation of commonly used AT commands:
  1. AT - This command is used to check communication between the module and the computer.
    For example,
    AT
    OK
    The command returns a result code OK if the computer (serial port) and module are connected properly. If any of module or SIM is not working, it would return a result code ERROR.
  2. +CMGF - This command is used to set the SMS mode. Either text or PDU mode can be selected by assigning 1 or 0 in the command.
    SYNTAX: AT+CMGF=<mode>
    0: for PDU mode
    1: for text mode
    The text mode of SMS is easier to operate but it allows limited features of SMS. The PDU (protocol data unit) allows more access to SMS services but the operator requires bit level knowledge of TPDUs. The headers and body of SMS are accessed in hex format in PDU mode so it allows availing more features.
    For example,
    AT+CMGF=1
    OK
  3. +CMGW - This command is used to store message in the SIM.
    SYNTAX: AT+CMGW=” Phone number”> Message to be stored Ctrl+z
    As one types AT+CMGW and phone number, ‘>’ sign appears on next line where one can type the message. Multiple line messages can be typed in this case. This is why the message is terminated by providing a ‘Ctrl+z’ combination. As Ctrl+z is pressed, the following information response is displayed on the screen.
    +CMGW: Number on which message has been stored
  4. +CMGS - This command is used to send a SMS message to a phone number.
    SYNTAX: AT+CMGS= serial number of message to be send.
    As the command AT+CMGS and serial number of message are entered, SMS is sent to the particular SIM.
    For example,
    AT+CMGS=1
    OK
  5. ATD - This command is used to dial or call a number.
    SYNTAX: ATD<Phone number>(Enter)
    For example,
    ATD123456789
  6. ATA - This command is used to answer a call. An incoming call is indicated by a message ‘RING’ which is repeated for every ring of the call. When the call ends ‘NO CARRIER’ is displayed on the screen.
    SYNTAX: ATA(Enter)
    As ATA followed by enter key is pressed, incoming call is answered.
    For example,
    RING
    RING
    ATA
  7. ATH - This command is used to disconnect remote user link with the GSM module.
    SYNTAX: ATH (Enter)
List of AT commands
The AT commands for both, GSM module and the mobile phone, are listed below. Some of these commands may not be supported by all the GSM modules available. Also there might be some commands which won’t be supported by some mobile handsets.
Testing
CommandDescription
ATChecking communication between the module and computer
Call control
CommandDescription
ATAAnswer command
ATDDial command
ATHHang up call
ATLMonitor speaker loudness
ATMMonitor speaker mode
ATOGo on-line
ATPSet pulse dial as default
ATTSet tone dial as default
AT+CSTASelect type of address
AT+CRCCellular result codes
Data card Control
CommandDescription
ATIIdentification
ATSSelect an S-register
ATZRecall stored profile
AT&FRestore factory settings
AT&VView active configuration
AT&WStore parameters in given profile
AT&YSelect Set as power up option
AT+CLCKFacility lock command
AT+COLPConnected line identification presentation
AT+GCAPRequest complete capabilities list
AT+GMIRequest manufacturer identification
AT+GMMRequest model identification
AT+GMRRequest revision identification
AT+GSNRequest product serial number identification (IMEI)
Phone control
CommandDescription
AT+CBCBattery charge
AT+CGMIRequest manufacturer identification
AT+CGMMRequest model identification
AT+CGMRRequest revision identification
AT+CGSNRequest product serial number identification
AT+CMEEReport mobile equipment error
AT+CPASPhone activity status
AT+CPBFFind phone book entries
AT+CPBRRead phone book entry
AT+CPBSSelect phone book memory storage
AT+CPBWWrite phone book entry
AT+CSCSSelect TE character set
AT+CSQSignal quality
Computer data interface
CommandDescription
ATECommand Echo
ATQResult code suppression
ATVDefine response format
ATXResponse range selection
AT&CDefine DCD usage
AT&DDefine DTR usage
AT&KSelect flow control
AT&QDefine communications mode option
AT&SDefine DSR option
AT+ICFDTE-DCE character framing
AT+IFCDTE-DCE Local flow control
AT+IPRFixed DTE rate
Service
CommandDescription
AT+CLIPCalling line identification presentation
AT+CRService reporting control
AT+DRData compression reporting
AT+ILRRDTE-DCE local rate reporting
Network Communication parameter
CommandDescription
ATBCommunications standard option
AT+CBSTSelect bearer service type
AT+CEERExtended error report
AT+CRLPRadio link protocol
AT+DSData compression
Miscellaneous
CommandDescription
A/Re-execute command line
AT?Command help
AT*CStart SMS interpreter
AT*TEnter SMS block mode protocol
AT*VActivate V.25bis mode
AT*NOKIATESTTest command
AT+CESPEnter SMS block mode protocol
SMS Text mode
CommandDescription
AT+CSMSSelect message service
AT+CPMSPreferred message storage
AT+CMGFMessage format
AT+CSCAService centre address
AT+CSMPSet text mode parameters
AT+CSDHShow text mode parameters
AT+CSCBSelect cell broadcast message types
AT+CSASSave settings
AT+CRESRestore settings
AT+CNMINew message indications to TE
AT+CMGLList messages
AT+CMGRRead message
AT+CMGSSend message
AT+CMSSSend message from storage
AT+CMGWWrite message to memory
AT+CMGDDelete message
SMS PDU mode
CommandDescription
AT+CMGLList Messages
AT+CMGRRead message
AT+CMGSSend message
SevenZero
Re: Tutorial on AT Commands for GSM/GPRS with microcontrollers
Post by SevenZero » Wed Sep 26, 2012 11:38 am
Here are some objectives that are fulfilled using AT Commands:
  1. Test the simple AT Command.
  2. Find out the IMEI number of the GSM Modem.
  3. Connect a call to a GSM mobile number (Dial a number).
  4. Send a text message to a mobile number.
AT Commands used to perform the above operations have been given below along with their output. (For complete list of AT Commands supported by GSM Modem, refer the list in tutorial on AT Commands.
    AT (Enter)
    OK
  2. Find out the IMEI number of the GSM modem
    AT+GSN (Enter)
    xxxxxxxxxxxxxxx(15- digit unique IMEI number)
    OK
  3. Dial a number
    ATDXXXXXXXXXX; (Enter) (10-digit mobile number)
    OK
  4. Send a text message.
    AT+CMGS= “XXXXXXXXXX” (Enter) (10-digit mobile number)
    >Hello ^z (Enter message after ‘>’ and use Ctrl+z to terminate the message)
Programming Steps:
  1. Store all AT commands into strings
  2. Set the baud rate of microcontroller to 9600bps
  3. Enable serial port. (Refer USART with PIC)
  4. Enable the global and peripheral interrupt bits of the INTCON register
  5. Configure Port D as input port
  6. Use if condition to detect the pressed switch
  7. As switch is pressed, process the corresponding AT command and transmit via USART
  8. Reception interrupt method is used to store the GSM output data into an array
  9. Display the stored value on the LCD. (Refer displaying text on LCD using PIC)
SevenZero
Post by SevenZero » Wed Sep 26, 2012 11:55 am
Sample circuit diagram on connecting a GPRS module such as the ones you can find from TRONIC.LK.
Here is a sample code is C language:
This code takes four choices as four inputs
Choice 1 : Test the simple AT Command
Choice 2 : Find out the IMEI number of the GSM Modem
Choice 3 : Connect a call to a GSM mobile number
Choice 4 : Send a text message to a mobile number
#define FREQ 12000000
#define baud 9600
#define spbrg_value (((FREQ/64)/baud)-1)
#define rs LATA.F0
#define rw LATA.F1
#define en LATA.F2
#define lcdport LATB
void tx_data(unsigned char);
unsigned char rx_data();
void lcd_ini();
void lcdcmd(unsigned char);
void lcddata(unsigned char);
void gsm_cmd(unsigned char *);
void output(void);
unsigned char value = 0;
int i=0,j,k,temp,flag,choice;
unsigned char *starting_text = "Enter choice=";
unsigned char *dial_text = "Dialing...";
unsigned char *at_cmd = "AT";
unsigned char *imei_cmd = "AT+GSN";
unsigned char *call_cmd = "ATD9xxxxxxxxx;"; // Provide a 10-Digit Mobile Number
unsigned char *sms_format = "AT+CMGF=1";
unsigned char *sms_write = "AT+CMGS=\"xxxxxxxxxx\""; // 10-Digit Mobile Number
unsigned char *sms = "Hello";
unsigned char *sms_report = "SMS Sent...";
unsigned char sms_terminate = 0x1A;
unsigned char enter = 0x0D;
unsigned char *data;
void main()
	TRISB=0; // Set Port B as output port
	LATB=0;
	TRISA=0;
	LATA=0;
	TRISD=0xFF;
	LATD=0;
	SPBRG=spbrg_value; // Fill SPBRG register to set the baud rate
	RCSTA.SPEN=1; // To activate serial port (Tx and Rx pins)
	TXSTA.TXEN=1; // Activate Transmissiom
	RCSTA.CREN=1; // Activate Reception
	PIE1.RCIE=1; // Enable Reception interrupt
	INTCON.GIE=1; // Enable Global interrupt
	INTCON.PEIE=1; // Enable Peripheral interrupt
	lcd_ini();
	while(1)
		k = 0;
		lcdcmd(0x80);
		while(starting_text[k]!='\0')
			lcddata(starting_text[k]);
			k++;
		//Check inputs
		//Choice 1
		if(PORTD.F0)
			gsm_cmd(at_cmd);
			output();
			Delay_ms(1000);
		//Choice 2
		if(PORTD.F1)
			gsm_cmd(imei_cmd);
			output();
			Delay_ms(1000);
		//Choice 3
		if(PORTD.F2)
			gsm_cmd(call_cmd);
			output();
			Delay_ms(1000);
		//Choice 4
		if(PORTD.F3)
			gsm_cmd(sms_format);
			output();
			Delay_ms(1000);
			gsm_cmd(sms_write);
			output();
			Delay_ms(1000);
			gsm_cmd(sms);
			output();
			tx_data(0x1A);
			Delay_ms(1000);
void gsm_cmd(unsigned char *string)
	i=0;j=0;
	while(string[i]!='\0')
		temp=0;
		if(string[i]==0x5C) // Not to send '\' cahracter
		i++;
		tx_data(string[i]); // Send by serial communication
		i++;
		while(temp!=1);
	temp=0;
	tx_data(enter); // Send ASCII code for 'Enter' key
	while(temp!=1);
void output(void) // To print data on LCD
	lcdcmd(0x01);
	i=-1;flag=0;
	while(i<j)
		if(flag>1)
			flag=0;
			Delay_ms(500);
			lcdcmd(0x01);
			lcdcmd(0x80);
		if(data[i]==0x0A) // This condition is to avoid double Enter
		// during execution of a command
			flag++;
			lcdcmd(0xc0);
		if(data[i]=='>'||data[i]=='"') // Not to print this character
			i++;
			lcdcmd(0xc0);
		if(data[i]!=0x0D&&data[i]!=0x0A&&data[i]!=0x1A) // Condition to print the data
		// except 'Enter','New line' and 'Submit'
			lcddata(data[i]);
			i++;
		else
			i++;
		Delay_ms(300);
	lcdcmd(0x01);
void tx_data(unsigned char serial_data) // Transmit data function
	TXREG = serial_data;
	while(PIR1.TXIF==0);
void interrupt()
	data[j]=RCREG; // Store the data into array when Reception interrupt occurs
	value=RCREG;
	j++;
	temp=1;
void lcd_ini()
	lcdcmd(0x38); // Configure the LCD in 8-bit mode, 2 line and 5x7 font
	lcdcmd(0x0C); // Display On and Cursor Off
	lcdcmd(0x01); // Clear display screen
	lcdcmd(0x06); // Increment cursor
	lcdcmd(0x80); // Set cursor position to 1st line, 1st column
void lcdcmd(unsigned char cmdout)
	lcdport=cmdout; //Send command to lcdport=PORTB
	rs=0;
	rw=0;
	en=1;
	Delay_ms(10);
	en=0;
void lcddata(unsigned char dataout)
	lcdport=dataout; //Send data to lcdport=PORTB
	rs=1;
	rw=0;
	en=1;
	Delay_ms(10);
	en=0;
nipunalanka
Sergeant
Sergeant
Post by nipunalanka » Wed Sep 26, 2012 7:51 pm
this cct can use phone,not chip
nipunalanka
Sergeant
Sergeant
Post by nipunalanka » Wed Sep 26, 2012 9:22 pm
no i wont connect to nokia 1110 or 1100 phone friend
Post by Neo » Fri Sep 28, 2012 8:28 pm
Nipuna, it is not possible to use AT commands with Nokia 1100 as there is no modem in there. But Nokia F-BUS protocol is there. But you need to use a different protocol to use that. Search for Nokia F-Bus.
Here are the connecters for f-bus.
Nokia 1100_1.jpg (7.53 KiB) Viewed 25410 times
Nokia 1100_2.jpg (5.58 KiB) Viewed 25410 times
Nokia 1100_3.gif (2.58 KiB) Viewed 25410 times
PINDESCRIPTION
1DAI CLK
2F-Bus Rx
3F-Bus Tx
4Gnd
5M-Bus
6Vpp
7Gnd
8BSI
9Vcc
Here is the link for Nokia 1100 schematics.
http://www.cpkb.org/wiki/Nokia_1100_110 ... c_download
This link has some good information about F-BUS.
http://www.embedtronics.com/nokia/fbus.html
maria752
Post by maria752 » Fri Mar 08, 2013 11:15 am
Have you any idea about HTC mobile circuit.... i have found Mic problem but it is hard to task to compile the solution. according to your upper solution this become very beneficiary for me....
