Smart carpet detects falls and strange footsteps
Post by Nipuna » Wed Sep 05, 2012 8:49 am
Douglas Heaven, reporter
(Image: Andrew Bret Wallis/Getty Images)
A team at the University of Manchester in the UK has developed a carpet that can detect when someone has fallen over or when unfamiliar feet walk across it.
Optical fibres in the carpet's underlay create a 2D pressure map that distorts when stepped on. Sensors around the carpet's edges then relay signals to a computer which is used to analyse the footstep patterns. When a change is detected - such as a sudden stumble and fall - an alarm can be set to sound.
By monitoring footsteps over time, the system can also learn people's walking patterns and watch out for subtle changes, such as a gradual favouring of one leg over the other. It could then be used to predict the onset of mobility problems in the elderly, for example.
The carpet could also be used as an intruder alert, says team member Patricia Scully. "In theory, we could identify footsteps of individuals and the shoes they are wearing," she says.
But it needn't all be about feet. The system is designed to be versatile, meaning that different sensors could instead be used to provide early warning of chemical spillages or fire. (
Camron
Sergeant
Sergeant
Re: Smart carpet detects falls and strange footsteps
Post by Camron » Thu Jul 04, 2013 11:43 am
How it will be work because it will sound when there is a little more pressure on your carpet.Even it may not be due to fall down a person.And also if you have the alarm monitoring services than the security company will be alerted without any reason.
http://www.yellowpages.com.au/qld/karan ... sting.html
