Create simple circuit using Logic gates
Nandika
Post by Nandika » Sun Aug 26, 2012 8:26 pm
Hello Friends,
This is a simple trick about simple logic circuit designing.I think,This is important for O/L IT and A/L Physics.
I use my poor English.Sorry for it.Never misunderstand.
I explain it using some examples.
Example 1:
Create a simple logic circuit for detect prime numbers from 0 to 7.
1.simple it,write a truth table...
convert 0 - 7 to binary.
0=000
1=001
2=010
3=011
7=111
2.write output as "1" for prime numbers only.
Table-
3.This is the point...
Get lines which output is "1" and write expression like following.
At input number is 2(=010) output is "1". Now write expression like this.
If input is "0",get as "Bar". In this line,A and C are "0",therefore,we get A bar and B bar.
:geek: ?
ok..this is another line.
Get line which input is 5.
A=1 ... therefore, write expression A.Not A bar.
B=0 ... therefore,write B bar.
C=1 ... Write C
At finally,Expression should be,
ok...End of trick.if you have a question,ask... :)
this is all expression corresponding to each line.
4.Now,input this all expression to OR gate.Get output(Q)...
5.Create circuit.
According above output expression we want,
A bar,B bar,C bar.therefore,We want to use NOT gate.
For get input for last OR gate,want to use three input AND gate.
Last we want a 4 input OR gate.
This is the circuit...
Example 2:
This is a question given G.C.E(A/L )-2004 Question number:-5.(iii)
Create a circuit for emergency lamp for automatically on at night power cutting.This light has a switch for light up the lamp at anytime.
Use following input.
A=1 : switch on
A=0 : switch off
B=1 : at night
B=0 : at day
C=1 : while power cutting
C=0 : while power ok
use output,
X=1 : emergency lamp on
X=0 : emergency lamp off
OK...Now answer....
1.write a truth table.
Truth table with corresponding AND expression.
2.Get lines which output is "1" and write expression.(red on above table.)
line 3 :
A=0
B=1
C=0
Therefore,Expression should be,
line 5 :
A=1
B=0
C=0
line 6 :
A=1
B=0
C=a
line 7 :
A=1
B=1
C=0
line 8 :
A=1
B=1
C=1
3.Write Output expression using OR operation.
4.Create circuit...
According to above output expression,
We want,
NOT Gate - 2 (for B bar and C bar,No A bar in expression)
3 input AND Gate - 5
5 input OR Gate - 1
OK
I think this may be useful to you. :)
If you have any problem,ask.
Sorry for my poor English again. :(
Re: Create simple circuit using Logic gates
Post by Rksk » Mon Aug 27, 2012 2:55 pm
Nice!
2012 question too was intererting. I done it first of all. :D
Nandika
Post by Nandika » Mon Aug 27, 2012 6:30 pm
:D
Did not answer Electronic question?I think It's the easiest question than others.
Post by Rksk » Mon Aug 27, 2012 6:44 pm
Nandika wrote::D
The Electronic one was on gates. And Electricle one was on resistance. Normally I don't like number calculations because I do mistakes. So I did electronic (on gates) one.
Post by Rksk » Mon Aug 27, 2012 11:28 pm
I simplified your both of circuits using Boolean Logics.
Boolean Logics
Boolean Logics
ec truth.gif (17.03 KiB) Viewed 21198 times
This is out of A/L physics, but used in Maths (probability).
01.
ec gate2.jpg (9.59 KiB) Viewed 21198 times
02.
ec gate.jpg (8.92 KiB) Viewed 21198 times
Nandika
Post by Nandika » Wed Aug 29, 2012 5:04 pm
Nice.... :)
I haven't more knowledge about this boolian equation.
Actually ,I wished someone post about simplified circuit.
Please,If you can post this simplification step by step.
Thanks.
Post by Rksk » Wed Aug 29, 2012 10:50 pm
oh! I've done two mistakes in my last reply. The correct ones are below.
Nandika
Post by Nandika » Sat Sep 01, 2012 4:45 pm
Excellent work Rksk.... :biggrin:
But,I have a problem in (02).
Where is + A.B.(C bar + C) in 3rd line of simplification?
Explain some about red sentence ..
thank you...
Post by Rksk » Sat Sep 01, 2012 9:31 pm
Nandika wrote: Where is + A.B.(C bar + C) in 3rd line of simplification?
A.B bar.(C bar + C) + A.B.(C bar + C) = A.B bar + A.B = A.(B bar + B) = A
Nandika wrote: Explain some about red sentence ..
Let's think X = Abar.B.Cbar + A
if A = 0; X = 1.B.Cbar + 0 = B.Cbar
if A = 1; X = 0.B.Cbar + 1 = B.Cbar + 1
now let's think Y = B.Cbar + A
if A = 0; Y = B.Cbar
if A = 1; Y = B.Cbar + 1
Both give same answer.
Nandika
Post by Nandika » Sun Sep 09, 2012 11:38 am
:D I got it,Rksk thanx
As this,According to Complementary law....
he he.PNG (35.73 KiB) Viewed 21104 times
Am I correct...Please tell?
