Changeable climate makes frogs vulnerable to disease
Post by Nipuna » Mon Aug 13, 2012 10:15 am
A Cuban tree frog (Image: John Pitcher/Design Pics Inc/Rex Features)
A more changeable climate will give some diseases the upper hand over their hosts. Experiments with frogs show that they are more vulnerable to a deadly fungus if the temperature changes unpredictably. As the climate becomes less predictable, amphibians may decline even faster.
A third of amphibians are threatened with extinction. That's mostly because their habitats are being destroyed. But they are also being hit hard by a disease called chytridiomycosis, caused by the fungus Batrachochytrium dendrobatidis.
Changes in average temperature and rainfall can affect the spread of disease, including chytridiomycosis, but nobody knows what a more varied and unpredictable climate will do, says Thomas Raffel of Oakland University in Rochester, Michigan. With his colleagues, he tried to find out using captive Cuban tree frogs (Osteopilus septentrionalis).
He exposed the frogs to chytrid fungus in incubators. Some were kept at constant temperatures, others experienced regular temperature changes that mimicked the day-night cycle, and others were subjected to random temperature changes. Frogs exposed to unpredictable temperature changes suffered higher levels of infection.
Fast adapters
Raffel thinks that's because the fungus can adapt faster to the temperature changes, as it is so much smaller and has a shorter generation time than its host. "The parasite does better with unpredictable temperature changes," he says.
Field data from populations of harlequin frogs showed that their numbers decline more when monthly temperatures fall abruptly, and that such sharp cooling periods have become more common as average temperatures have risen. That suggests that increasing variability in climate is already affecting wild frogs.
Climate change will take a massive toll on the world's biodiversity, because many species will find that their habitats are too hot or dry for them. But the models predicting climate's effects are based on changes in average conditions, and do not factor in increases in climate variability or extreme events.
"We're highlighting this glaring hole in our understanding of how climate change affects biodiversity," Raffel says. He says it's too early to say how big a role variability will play. However, he suspects that it will simply speed up the declines of species that are already threatened by chytrid fungus, rather than threatening additional species.
As climate models improve, it should be possible to identify the areas that will experience greater variability in their climate. "Then you know where to focus your conservation efforts," Raffel says.
Journal reference: Nature Climate Change, DOI: 10.1038/nclimate1659
