Make LED matrix array using a single microcontroller
Shane
Post by Shane » Fri Jul 13, 2012 10:03 pm
Circuit diagram for a moving LED matrix display.
Re: Make LED matrix array using a single microcontroller
Post by Rksk » Sat Sep 22, 2012 2:24 pm
Shane wrote:Circuit diagram for a moving LED matrix display.
Can I use this for a large matrix display (like 16*64) ?
Will it show good outputs?
Shane
Post by Shane » Sat Sep 22, 2012 3:17 pm
Think about it as this. You TV refreshes the display 25 times per second. With two fields, it is like 50 fields per second.
With a microcontroller, How fast you think you can refresh these LED displays ? That's how this scanning method work. Though it can be logically thought as drawing to one display at a time, due its speed, no one will notice that. This is the common method used. Good luck and keep us updated.
Post by Rksk » Sat Sep 22, 2012 3:22 pm
Shane wrote:Think about it as this. You TV refreshes the display 25 times per second. With two fields, it is like 50 fields per second.
Thank you, I'll try to see it practically.
Post by Neo » Sun Sep 23, 2012 5:01 pm
Writing firmware for this.....
If you can understand the basic operation of a latch and shift register, it is easy to write the firmware by yourself. 74HC259 is a latch and 74HC595 is a shift register. If you want to become a good electronic engineer, it is a must to learn how to read a datasheet carefully and understand.
Here are the datasheets.
http://www.nxp.com/documents/data_sheet/74HC_HCT259.pdf
http://www.nxp.com/documents/data_sheet/74HC_HCT595.pdf
chanakalin
Post by chanakalin » Wed Sep 26, 2012 10:19 pm
74HC595 datasheet is not clear to beginners. arduino.cc/en/Tutorial/ShiftOut helps me to understand it.
It says "Your account does not have permission to post links or domain/page references." while adding the link :cry:
