If you get this error while installing a php script, etc... you can try this solution. In some websites, this is seriously mentioned as a SSI (Server Side Includes) but in many cases I found it a simple issue which can be sorted out in few minutes.
Check whether all your folder permissions as are set to 755 and file permissions to 644. In 90% of cases I found that this is caused by bad folder permission setting.
Reply to this thread if you find this helpful or you sorted out it in another way.
Thanks!
- It is currently Sun Sep 27, 2026 6:45 am
Solved: [an error occurred while processing this directive]
