List of Common Microcontrollers
Shane
Post by Shane » Fri Sep 25, 2009 7:25 pm
AMCC
Until May 2004, these ?Cs were developed and marketed by IBM, whose 4xx family was sold to Applied Micro Circuits Corporation.
  • 403 PowerPC CPU
    • PPC 403GCX
  • 405 PowerPC CPU
    • PPC 405EP
    • PPC 405GP/CR
    • PPC 405GPr
    • PPC NPe405H/L
  • 440 PowerPC Book-E CPU
    • PPC 440GP
    • PPC 440GX
    • PPC 440EP/EPx/GRx
    • PPC 440SP/SPe
Atmel
  • AT89 series (Intel 8051 architecture)
  • AT90, ATtiny, ATMega series (AVR architecture) (Atmel Norway design)
  • AT91SAM (ARM architecture)
  • AVR32 (32-bit AVR architecture)
  • MARC4
Cypress MicroSystems
  • CY8C2xxxx (PSoC)
Dallas Semiconductor
  • 8051 Family
  • MAXQ RISC Family
  • Secure Micros Family
Freescale Semiconductor
Until 2004, these ?Cs were developed and marketed by Motorola, whose semiconductor division was spun-off to establish Freescale.
  • 8-bit
    • 68HC05 (CPU05)
    • 68HC08 (CPU08)
    • 68HC11 (CPU11)
  • 16-bit
    • 68HC12 (CPU12)
    • 68HC16 (CPU16)
    • Freescale DSP56800 (DSPcontroller)
  • 32-bit
    • Freescale 683XX (CPU32)
    • MPC500
    • MPC 860 (PowerQUICC)
    • MPC 8240/8250 (PowerQUICC II)
    • MPC 8540/8555/8560 (PowerQUICC III)
Fujitsu
  • FMC Family (8/16 bit)
  • FR Family (32 bit)
  • FR-V Family (32 bit RISC)
Holtek
  • HT8
Infineon
  • 8-bit
    • XC800 family
    • C500/C800 family
  • 16-bit
    • XC166 family
  • 32-bit family
    • TRICORE family
Intel
  • 8-bit
    • MCS-48 (8048 family - also incl. 8035, 8038, 8039, 8040, 8X42, 8X49, 8050; X=0 or 7)
    • MCS-51 (8051 family - also incl. 8X31, 8X32, 8X52; X=0, 3, or 7)
    • 8xC251
  • 16-bit
    • 80186/80188
    • MCS-96 (8096 family - also incl. 8061)
    • MXS296
  • 32-bit
    • 80386EX (i386EX)
    • 80960 (i960)
Microchip Technology
  • 8 and 16-bit microcontrollers with 12 to 24-bit instructions
  • ability to include DSP function
  • 12-bit instruction PIC
  • 14-bit instruction PIC
    • PIC16F84
  • 16-bit instruction PIC
National Semiconductor
  • COP8
  • CR16
NEC
  • 17K
  • V25
  • 75X
  • 78K
  • V850
Philips Semiconductors
  • LPC3000
  • LPC2000
Renesas Technology
(Renesas is a joint venture of Hitachi and Mitsubishi Electric.)
  • H8
  • SH
  • M16C
  • M32R
Silabs
  • C8051F300
    • QFN11 case(3x3mm), 25MIPS, 8kb Flash, 256b ram 8io, UART,SMBus, 3 timers, 8 bit 8 ch 500kbs ADC, temp, comp.
  • C8051F120
    • TQFP100 case, 128k Flash, 8448b RAM, 64io, 2 UARTS, SMBus, SPI, 5 timers, 8ch 12b + 8ch 8b ADC, 2ch 12 bit DAC, temp, 2xcomp, 16x16MAC.
    • The ToolStick of Silabs is an USB stick size development tool with a limited compiler including a C8051F300 target and an USB MCU C8051F321.
Silicon Motion
  • SM2XX Family - Flash Memory Card Controllers
  • SM321 - USB 2.0
  • SM323 - USB 2.0
  • SM323E - USB 2.0
    • Silicon Motion's SM321E and SM324 controllers support SLC and MLC NAND flash from Samsung, Hynix, Toshiba and ST Micro as well as flash products from Renesas, Infineon and Micron. The SM321E is available in a 48-pin LQFP package and a 44-pin LGA package. The SM321E supports up to 4 SLC or MLC NAND flash chips with 4 bytes / 528 bytes ECC
  • SM324 - USB 2.0
    • Supports dual-channel data transfer at read speeds of 233x (35MB/sec) and write speeds of 160x (24MB/sec), making it the fastest USB 2.0 flash disk controller in the market. The SM324 also has serial peripheral interface (SPI) which allows for not only Master and Slave modes, but the flexibility to develop more functionality into USB flash disk (UFD) products such as GPS, fingerprint sensor, Bluetooth and memory-capacity display. The SM324 is available in a 64-pin LQFP package. The SM324 supports 8 SLC or MLC NAND flash chips with 4 bytes / 528 bytes ECC.
  • SM330 - USB 2.0
  • SM501 - Mobile Graphics
  • SM712 - Mobile Graphics
  • SM722 - Mobile Graphics
  • SM340 - MP3/JPEG
  • SM350 - MP3/JPEG
  • SM370 - Image processing
STMicroelectronics
  • ST 62
  • ST 7
  • ST 10
  • ?PSD
Texas Instruments
  • TMS370
  • MSP430
Toshiba
  • TLCS-870 (8-bit CISC)
  • TLCS-900 (16 and 32-bit CISC)
  • TX19A (32-bit RISC)
Western Design Center
  • 8-bit
    • W65C02-based ?Cs
  • 16-bit
    • W65816-based ?Cs
Ubicom
  • SX-20 SX-28, SX-48, SX-52
    • Ubicom's SX series is an 8 bit microcontroller which has unusually high speed, up to 75Mhz (75 MIPS), and a high degree of flexibility. Some users have referred to these microcontrollers as PICs on steroids. While Ubicom's SX micros are limited in variety, their high speed and additional resources allow programmers to create 'virtual devices' as required. Refer to Parallax's Web site for information, as they are the main distributor of these devices.
  • IP2022
    • Ubicom's IP2022 is a high performance (120 MIPs) 8 bit microcontroller. Features include: 64k FLASH code memory, 16k PRAM (fast code and packet buffering), 4k data memory, 8-channel A/D, various timers, and on-chip support for Ethernet, USB, UART, SPI and GPSI interfaces.
  • IP3022
    • IP3022 is Ubicom's latest high performance 32bit processor running at 250Mhz featuring 8 hardware threads. It is specifically targeted at Wireless Routers.
Xemics
  • XE8000 8-bit microcontroller family
Xilinx
  • Microblaze softcore 32 bit microcontroller
  • Picoblaze softcore 8 bit microcontroller
ZiLOG
Zilog's (primary) microcontroller families, in chronological order:
  • Zilog Z8 - 8-bit Harvard architecture ROM / EPROM / OTP microcontroller with on-chip SRAM.
  • Zilog Z180 - Z80 based microcontroller; on-chip peripherals, but external memory; 1MB address space.
  • Zilog eZ8 - Better pipelined Z8 with on-chip Flash memory; 2-3 times as clock cycle efficient as original Z8.
  • Zilog eZ80 - Fast 8/16/24-bit Z80 with FLASH, SRAM, peripherals, and linear addressing of 16MB; 3-4 times as clock cycle efficient as original Z80.
...And endless BASIC programmed MCUs
For almost every bare microcontroller manufacturer, there are a dozen little companies repacking them into a more hobbyist friendly package. Their product is often an MCU preloaded with a BASIC interpreter, soldered onto a Dual Inline Pin board along with a power regulator and other goodies. PICs seem to be very popular here, possibly due to good static protection. More powerful examples (e.g. faster execution, more RAM and code space) seem to be based on Atmel AVR or Hitachi chips and now ARM.
Comfile Technology Inc.
Comfile Technology Inc. produces a series of microcontrollers branded as CUBLOC and CuTOUCH, using the Atmel ATmega128 processor. They are very price competitive, being aimed at industrial applications, and include some nice features such as Ladder Logic in addition to BASIC, a huge 80Kbyte program memory, and hardware pulse width modulation. Their focus in on developing industrial controllers which are fast, easy-to-use, and versatile. Comfile Technology's CuTOUCH is a visual Touch-screen controller that can be programmed in BASIC and Ladder Logic. This product is the first of its kind in the world yet.
Parallax, Inc.
  • BASIC Stamp - The Big Name in BASIC microcontrollers. They are Microchip PICmicros programmed with an interpreter that processes the program stored in an external EEPROM. Several different modules are available of varying processing speeds, RAM, and EEPROM sizes. Most popular is the original BASIC Stamp 2 module. The BASIC Stamp is used by Parallax as a platform for introductory programming and robotic kits.
  • SX-Key - Parallax's development tool for the SX line of microcontrollers, supporting every SX chip commercially available. Using free SX-Key software (Assembly language), or the SX/B Compiler (BASIC-style language) from Parallax, the SX-Key programming tool can program SX chips in-system and perform in-circuit source-level debugging.
PICAXE
This range of controllers is based upon Microchip PICmicro's programmed with a BASIC interpreter. Using internal EEPROM or Flash to store the user's program they deliver a single-chip solution and are quite inexpensive. A PICAXE programmer is simply a serial plug plus two resistors. Complete development software, comprehensive documentation and application notes are all available free of charge.
The BASIC-like programming language is almost identical to that used by Parallax's Basic Stamp 1 (BS1) but has been enhanced to support on-chip hardware and additional functionality. In common with the BS1 programming language, the PICAXE has support only for a limited number of variables and lacks block-structured programming constructs.
Initially targeted at the UK educational sector, use of the PICAXE has spread to hobbyists, semi-professionals and it can also be found inside commercial products. With its user base in many countries, the PICAXE has steadily gained a good international reputation.
ZX-24, ZX-40
The ZX series MCUs are based on the Atmel ATmega32 processor and run a Virtual Machine that features built-in multi-tasking, 32-bit floating point math and over 1K of RAM for user's programs. Multi-tasking facilitates a more structured approach to coding for interface devices that require prompt service, e.g. serial devices, infrared remotes, etc.
The programming language for the ZX series is ZBasic, a modern dialect of Basic modelled after Microsoft's Visual Basic. The biggest improvement over the typical MCU Basic dialect is parametrized subroutines/functions that support local variables. Strong type checking is another improvement that aids in writing correct programs more quickly.
Coridium ARMexpress
ARMexpress is the first of a new family of DIP-24 (stamp-sized) controllers that combine a 60 MHz ARM CPU with a built-in BASIC compiler to achieve new levels of performance in this form factor. This combination makes this simple to use but very fast controller a good choice for the prototype builder or system integrator. 40K of code and 40K of data are available to the user, and code speed rivals that of programs written in C. The dialect of BASIC conforms more to Visual BASIC, but has hardware extensions like PBASIC.
Re: List of Common Microcontrollers
Post by Rksk » Sun Apr 18, 2010 3:25 pm
Pls post a List of Common Microcontrollers wich can buy in Sri Lanka :D
Shane
Post by Shane » Sun Apr 18, 2010 4:52 pm
Why should I? You find it yourself 8-)
Call one of your local electronic shops.... it's that easy :lol:
Post by Rksk » Sun Apr 18, 2010 4:59 pm
No shane, u don't want to do it.
i think magento know it.
Shane
Post by Shane » Sun Apr 18, 2010 5:18 pm
mmm..okay.. Do you think you need an electronic engineer to call local shops for you? What a world... :lol:
Post by Neo » Sun Apr 18, 2010 5:27 pm
Hey Shany, How are you?
Don't worry about this. RKSK is a schoolboy who is going to start micros and we are giving him some backing.
RKSK,
I was clear to you that 16F84 (~ Rs. 350) and 16F877 (~ Rs. 500) are highly available and easy to handle for a person like you. So just give a start with them. I don't think Magneto can recommend you anything further than this as I heard he also used to recommend these for beginners like you.
Shane is a very nice man and an experienced Swedish engineer. Make sure you write politely for them when you require help. They are not paid in any mean from you so respect the fact that they spend some valuable time in their busy life to give you some help.
Post by Rksk » Sun Apr 18, 2010 5:36 pm
Thankz a lot to Shane and Neo for helping me.
Kavee
Corporal
Corporal
Post by Kavee » Mon Apr 19, 2010 9:26 am
Pay a visit to 1st cross street, pettah, and try your luck at various electronic component shops. Some of them have PIC chips, but don't be too smart asking for PIC or Microconrollers. Because you will get NO for an answer for sure. If you can be specific and ask for 16F84, then they will know. If you try with the code, you can find a range of micros with a little bit of hunting. Some sales guys now know about microcontrollers, but most of them don't. It is just an 'IC' for them and pricing is based on the number of pins and size. Since they are not fast moving items, they tend to sell it for cheaper just to clear a pocket in their shelves.
If you ask for 50pcs or more, and can wait for some few weeks, they will get you 16F84 at Rs.150~200. If you have other friends with similar needs, then this will be a good option. You will definitely need few spares in hand when first tinkering with micros, since frying couple of them in the learning process is not a rare sight.
Alternatively, you may buy direct from eBAY. Our custom officers are not bothered with small postal packages and you will most definitely delivered it to your doorstep through the postman. Cost of postage is a bit high, but again you can be creative and go for combine shipping with other items with same seller, so you will save on shipping. Word of caution, don't order too many things which can make your parcel bigger and bulkier, as it can arouse suspicion at customs and you might be asked to pay a visit to them for declaration of the detained parcel.
Post by Rksk » Mon Apr 19, 2010 9:49 am
Thankz. i will try.
RAT16F88
Post by RAT16F88 » Sun Nov 21, 2010 12:34 am
here s a list of most common PIC's
P
PIC 16f84a -18 pin (only I/O PINs 13 pins,good for LED flashers as a biginer :D )
PIC 16f88 -18 pin (INTRC,PWM,USART,ADC & counters)
PIC 16f877a- 40 pin
PIC 18f452 -40 pin
PIC 18f2550 -20 pin (USB capable)
PIC 18f4550-40 pin
(USB capable)
