How was airline bomb made to be 'undetectable'?
Post by Nipuna » Sun May 13, 2012 9:01 am
Ongoing research is looking into MRI imaging to distinguish between safe and dangerous liquids (Image: Marcus Moresby/Getty Images)
An Al-Qaida plot to bring down an aeroplane using a more sophisticated version of the "underwear" bomb used on Christmas Day 2009, has been foiled by US intelligence, it was revealed today.
How close were we to an attack?
US officials said the plot was stopped before it had reached an airport, and the device was seized before any particular flight had been targeted. The FBI said initial examination shows that the device was very similar in design to IEDs used by Al-Qaida in the Middle East.
What was unusual about this device was that it was designed to be almost impossible to detect by airline security. Senator Dianne Feinstein, chairman of the Senate Select Committee on Intelligence, told the Associated Press that the device was "a specific type of bomb that is of new design and very difficult to detect by magnetometer".
So how can a bomb be detonated without the use of metal components like batteries?
Homemade electrical systems can be quite easily made with very small amounts of metal, says Sidney Alford, of Alford Technologies, an explosives consultancy in Chippenham, Wiltshire, UK. Detonators do not necessarily need metal components, and the amount of wire can be kept to a minimum. Such small amounts are unlikely to be picked up by standard airline security metal detectors. When required, an electric battery to set off the device could be taken from some other innocent electrical device during the flight, says Alford.
But even a small amount of metal means there is a risk of detection. What about entirely non-metal devices?
This implies the use of purely chemical means of initiation, which may have been the case here, Alford says.
How would this work?
Bombs need a main "secondary" charge of high explosives, and the means to ignite this charge, using a smaller detonator. A detonator is usually just a small amount of "primary explosive", which only needs a spark to ignite but is violent enough to set off the main charge.
How could the main charge be made undetectable?
There are many ways, says Alford. There are a number of powders that are conventionally used alone – or as components of plastic explosives or conventional bombs, mines and shells – which would be appropriate. It was reported that previously unsuccessful bombers used one such substance.
But as far as the primary explosive is concerned, conventional explosives usually contain at least some component based upon a heavy metal. That is to the bomber's advantage, Alford says, but the downside for them is that these materials show up well on X-ray images.
Substitution of a purely organic powder, such as one of the organic peroxide compounds already used by terrorists, would avoid the projection of such a distinctive image. The means of ignition can be as simple as a match and the box that contains it.
But would this mean the bomber would somehow have to get a box of matches through security?
Not necessarily, says Alford. The "underpants" bomber used a combination of a liquid and solid that ignite when brought into contact with one another. There is no shortage of such candidate "hypergolic" combinations of chemicals. Also, some devices contain so much primary explosive that no main charge is required.
So what now? If we can't rely on metal detectors, how can we stop explosives getting through security?
A number of research projects are underway, designed to detect the chemical content of explosives. Some use MRI imaging to tell the difference between safe and dangerous liquids. Other commercial systems sensors use X-rays to detect the telltale signatures of organic materials, such as the liquid explosives TATP and nitroglycerine. Neither system is used by airport security at commercial airports.
