Help My Project(12CH LED Driver)??
Embedded Systems Topics
Nandika
Post by Nandika » Mon May 07, 2012 11:32 am
Hi Friends,
I have some basic knowledge about MicroC.
I am coding for 12 channel LED drivr/flasher for Poson :)
I have MicroC and Protus for debug/coding it. ;)
However,I have Little problems.
This is my 1st
I want a command to MikroC for Manipulate each bit of Port.
Simply,
i want to turn on channel4 witch was connected to 3rd bit/pin of PORTB.
I have tried before,But :cry:
My Try....And My MikroC About window
I have also used this code.
PORTB.F2
please,Give me a command or example for this.
Nandika
Re: Help My Project(12CH LED Driver)??
Post by Nandika » Mon May 07, 2012 11:52 am
2nd question is....
I want to add heder file like C++.
please,tel me how to add it and #include it.
Thans
Nandika
Post by Nandika » Mon May 07, 2012 12:21 pm
:biggrin: :biggrin:
Friends,
It's OK
I could solve my problem.
Answer for 1st question is,
PORTX.Fn
X=PORTA,PORTB.....
n=pin/bit(0,1,2....)
Answer for 2nd question is,
1.manually create .h file in project folder.
2.use add file in Project manager of MikroC.
3.code this(it's like C++ :) )
#include filename.h
filename=manually created file name
However,Your help will want me for this Project. :) :)
SevenZero
Post by SevenZero » Mon May 07, 2012 1:56 pm
I'm not discouraging you on Mikro C. But I should say HI-TECH C is very good for PIC, dsPIC programming. It is the only 3rd part C compiler recommended by Microchip. The main point I love about HI-TECH C is, it is very straightforward. MikroC has fancy libraries which make it looks like a very high level environment. I don't see any advantage in driving a say LCD with a library where we don't know what is happening inside. No fun when we don't know what is happening. Assembly is the best, but since time is also important C is the most suitable option.
http://www.microchip.com/stellent/idcpl ... e=en534868
Nandika
Post by Nandika » Mon May 07, 2012 3:21 pm
Thank you ZevenZero,
I really know HI-TECH C is good.before,i worked with HI-TECH C.I created some small project using it. :D
But,Now i haven't HI-TECH C.I must download it feature.
Actually,I can understand that you said.I'm a beginner for PIC.therefore,I must use Assembly like languages.It is advice for understand reality of Micro controller.
Till,I download HI-TECH C,please help me for Mikro C.(I never discourage :) )
Nandika
Now,I have some big problem.I want to adjust Time delay in code.Now,it's constant.like this,
Delay_ms(500)
I want to add Variable resistor for adjust it.
I used PIC16F877A.PORTB,C,D ware dedicated to LED channels.
I have PORTA for connect VR.
Please,give me example code or learning source for do this.
SemiconductorCat
Post by SemiconductorCat » Mon May 07, 2012 5:15 pm
There are two methods to do this.
1. Saw tooth method , with a op-amp and count duty cycle. [analog jam , I love this believe me,I could help you
on this].
2. ADC way.
Choose the first method if your micro does not contain a ADC unit.
Which way you prefer.
Nandika
Post by Nandika » Mon May 07, 2012 5:47 pm
Thanks SemiconductorCat,
I like to learn both.
But,Now,I like to use 2nd one.because,i think,it's easy for this time.
My micro is PIC16F877A.it has ADC unit.
First, tell me ADC Way
After,if you can,if you have time, tell me OP-AMP,saw tooth method.really,i like it.because,i am also learning about OP-AMP. :clap:
SemiconductorCat
Post by SemiconductorCat » Mon May 07, 2012 5:50 pm
There is a example here :
http://www.mikroe.com/download/eng/docu ... ibrary.htm
as it sounds the first two methods is by using ADC.
and last one uses internal RC jam.
Nandika
Post by Nandika » Mon May 07, 2012 6:07 pm
Nice.. Thank you SemiconductorCat,
I already have it in MiKroC user manual.I forgot that.
ADC system is easy,But, :x .We can't get more idea from it.
If u can Please,explain your OP-AMP system. :)
not now..
Return to “Embedded Systems”
