Java Programming History Part-7
Java programming topics
shchamon
Sergeant
Sergeant
Post by shchamon » Sat Apr 21, 2012 1:56 pm
Read more Java Servlet
A servlet is a Java programming language class used to extend the capabilities of servers that host applications access via a request-response programming model. Although servlets can respond to any type of request, they are commonly used to extend the applications hosted by Web servers. Thus, it can be thought of as a Java Applet that runs on a server instead of a browser.Image
Introduction
A Servlet is a java based server side web technology. As the name implies, it serves a client request and receives a response from the server. Technically speaking a Servlet is a Java class in Java EE that conforms to the Java Servlet API, a protocol by which a Java class may respond to requests. They are not tied to a specific client-server protocol, but are most often used with the HTTP protocol. Therefore, the word "Servlet" is often used in the meaning of "HTTP Servlet". Thus, a software developer may use a servlet to add dynamic content to a Web server using the Java platform. The generated content is commonly HTML, but may be other data such as XML. Servlets are the Java counterpart to non-Java dynamic Web content technologies such as CGI and ASP.NET. Servlets can maintain state in session variables across many server transactions by using HTTP cookies, or URL rewriting.
To deploy and run a Servlet, a Web container must be used. A Web container (also known as a Servlet container) is essentially the component of a Web server that interacts with the servlets. The Web container is responsible for managing the lifecycle of servlets, mapping a URL to a particular servlet and ensuring that the URL requester has the correct access rights. The servlet API, contained in the Java package hierarchy javax.servlet, defines the expected interactions of the Web container and a servlet.
A Servlet is an object that receives a request and generates a response based on that request. The basic servlet package defines Java objects to represent servlet requests and responses, as well as objects to reflect the servlet's configuration parameters and execution environment. The package javax.servlet.http defines HTTP-specific subclasses of the generic servlet elements, including session management objects that track multiple requests and responses between the Web server and a client. Servlets may be packaged in a WAR file as a Web application.
Servlets can be generated automatically from JavaServer Pages (JSP) by the JavaServer Pages compiler. The difference between Servlets and JSP is that Servlets typically embed HTML inside Java code, while JSPs embed Java code in HTML. While the direct usage of Servlets to generate HTML (as shown in the example below) has become rare, the higher level MVC web framework in Java EE (JSF) still explicitly uses the Servlet technology for the low level request/response handling via the FacesServlet. A somewhat older usage is to use servlets in conjunction with JSPs in a pattern called "Model 2", which is a flavor of the model-view-controller pattern.
A servlet is a Java component that can be plugged into a Java-enabled web server to provide custom services. These services can include:
Servlet History
The complete servlet specification was created by Sun Microsystems, with version 1.0 finalized in June 1997. Starting with version 2.3, the servlet specification was developed under the Java Community Process. JSR 53 defined both the Servlet 2.3 and JavaServer Page 1.2 specifications. JSR 154 specifies the Servlet 2.4 and 2.5 specifications. As of March 26, 2010, the current version of the servlet specification is 3.0.
In his blog on java.net, Sun veteran and Glassfish lead Jim Driscoll details the history of servlet technology. James Gosling first thought of servlets in the early days of Java, but the concept did not become a product until Sun shipped the Java Web Server product. This was before what is now the Java Platform, Enterprise Edition was made into a specification.
Servlet API history
Servlet API version.doc
(30 KiB) Downloaded 922 times
Advantages over CGI
The advantages of using servlets are their fast performance and ease of use combined with more power over traditional CGI (Common Gateway Interface). Traditional CGI scripts written in Java have a number of disadvantages when it comes to performance:
When an HTTP request is made, a new process is created for each call of the CGI script. This overhead of process creation can be very system-intensive, especially when the script does relatively fast operations. Thus, process creation will take more time than CGI script execution. Java servlets solve this, as a servlet is not a separate process. Each request to be handled by a servlet is handled by a separate Java thread within the Web server process, omitting separate process forking by the HTTP daemon.
Simultaneous CGI request causes the CGI script to be copied and loaded into memory as many times as there are requests. However, with servlets, there are the same amounts of threads as requests, but there will only be one copy of the servlet class created in memory that stays there also between requests.
Only a single instance answers all requests concurrently. This reduces memory usage and makes the management of persistent data easy.
A servlet can be run by a servlet engine in a restrictive environment, called a sandbox. This is similar to an applet that runs in the sandbox of the Web browser. This makes a restrictive use of potentially harmful servlets possible
Life cycle of a servlet
• During initialization stage of the Servlet life cycle, the web container initializes the servlet instance by calling the init() method. The container passes an object implementing the ServletConfig interface via the init() method. This configuration object allows the servlet to access name-value initialization parameters from the web application.
• After initialization, the servlet can service client requests. Each request is serviced in its own separate thread. The Web container calls the service() method of the servlet for every request. The service() method determines the kind of request being made and dispatches it to an appropriate method to handle the request. The developer of the servlet must provide an implementation for these methods. If a request for a method that is not implemented by the servlet is made, the method of the parent class is called, typically resulting in an error being returned to the requester.
• Finally, the Web container calls the destroy() method that takes the servlet out of service. The destroy() method, like init(), is called only once in the lifecycle of a servlet.
Three methods are central to the life cycle of a servlet. These are init( ), service( ), and destroy( ). They are implemented by every servlet and are invoked at specific times by the server. Let us consider a typical user scenario to understand when these methods are called.
1. Assume that a user enters a Uniform Resource Locator (URL) to a web browser.
(a) The browser then generates an HTTP request for this URL.
(b) This request is then sent to the appropriate server.
2. The HTTP request is received by the web server.
(a) The server maps this request to a particular servlet.
(b) The servlet is dynamically retrieved and loaded into the address space of the server.
3. The server invokes the init() method of the servlet.
(a) This method is invoked only when the servlet is first loaded into memory.
(b) It is possible to pass initialization parameters to the servlet so it may configure itself.
4. The server invokes the service() method of the servlet.
(a) This method is called to process the HTTP request.
(b) You will see that it is possible for the servlet to read data that has been provided in the HTTP request.
(c) It may also formulate an HTTP response for the client.
5. The servlet remains in the server’s address space and is available to process any other HTTP requests received from clients.
(a) The service() method is called for each HTTP request.
6. The server may, at some point, decide to unload the servlet from its memory.
(a) The algorithms by which this determination is made are specific to each server.
7. The server calls the destroy() method to relinquish any resources such as file handles that are allocated for the servlet; important data may be saved to a persistent store.
8. The memory allocated for the servlet and its objects can then be garbage collected.
N:B:-See more Java Programming History Part-8 :arrow:
Return to “Java Programming”
