After searching many forums I couldn't find a way to sort this out. Finally I found it was due to a missing setting in 'hosting' table. The path to root folder was missing. I logged in to the psa database and manually entered the path to domain's root folder and it all then executed /usr/local/psa/admin/sbin/websrvmng -a -v to rebuild all apache includes.
All started to work after than. Hope this will help someone.
See How to access Plesk database? if you don't know how to edit Plesk database.
How to solve Plesk Internal error: is out of webspace
Linux OS Topics
