What is the file name for do this?
Windows OS Specific Topics
Nandika
Post by Nandika » Wed Mar 14, 2012 11:02 pm
Hi All,
I cant enter/start/run Task manager of Windows XP computer.when press Alt+Ctrl+Delete or Ctrl+Shift+Esc,appear a Error message.it contain "Task Manager has been disabled by your administrator".
when right click on task bar,disable "Start task manager" command.
I had a file name for solve this.but,i don't remember it now.it is a .cpl file.but,not in control panel.
it can lock and unlock task manager,set log in messages,....ect.it is a Dialog box(GUI).
According to this describe,
Please give me that .cpl file name.
Thanks...
Nandika
Re: What is the file name for do this?
Post by Nandika » Wed Mar 14, 2012 11:25 pm
He Friends,
I found it in very quickly using Google...
This Microsoft page has a all system.
http://support.microsoft.com/kb/555480
not a .cpl file.it is "gpedit.msc". :o
Get .reg file to do it easily.(See Attachment)
alt+ctrl+del_Default.rar
Set Alt+Ctrl+Delete to default.
(327 Bytes) Downloaded 1018 times
Post by Saman » Thu Mar 15, 2012 1:44 pm
Hi Nandika,
It is likely that you are exposed to spyware which usually does such abnormal things. It is recommended for you to install a spyware scanner such as Malwarebytes and remove the root cause of the problem. After that install a good virus guard such as AVAST free version (though it is free, it is very very good).
Hope that helps!
Nandika
Post by Nandika » Fri Mar 16, 2012 6:47 pm
Hi Friends,
Saman wrote:Hi Nandika,
Hope that helps!
I have ESET NOD 32 Antivirus 4 as my virus guard.Is not good my friends?it can online update using very small update file downloading.it is a main factor for use this.
However,AVAST is very very good....
Please,tell me according to your experience and knowledge,what is the best Antivirus between this both? :?: :?: :?:
Post by Saman » Tue Mar 20, 2012 4:29 pm
I used both for many years and now only using AVAST free for my lap at home. AVAST allows the free version to be legally used for home users. I'm using that for more than 3 years now and a very satisfied user. My vote is definitely with AVAST free version.
Nandika
Post by Nandika » Tue Mar 20, 2012 6:32 pm
Thank you Saman,
I will try to AVAST.
Return to “Windows”
