Help for my background color changer Java program
Java programming topics
Post by Nipuna » Tue Mar 06, 2012 10:05 am
Hi friends.
With my simple Java knowledge I made a program yesterday and it didn't work as expected. So I wrote it again today and posting here to get helps from you guys :)
In this program I tried to make a program to change background of a window according to seconds, Like this. After 1 second background is blue then red and etc... I wrote this to gain my knowledge so even changing to 5 colors is enough. :)
So I searched the net and and found there is a class for this in the API called Timer. And I found out there are 2 classes in Java that has same name, Here are they,
java.util.Timer
and
javax.swing.Timer
So for my task I found out that second one is the one I need. So I used it. Because I know the other stuff what I can't figure out is the timer. Finally I found that too :) So I made a program by using that. And using API I learned how to use it's functions and of course how to use the class itself too :)
But my problem is, I could only write the program only to change to one color after 1 second then I couldn't figure out how to change the color according to seconds.
Program only works 1 time then stay as is, Of course you can see that I haven't written the other stuff to do the rest, I did so because I couldn't figure out it :?
So here goes the code,
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.Color;
import javax.swing.JFrame;
import javax.swing.Timer;
public class BGChanger extends JFrame{
	private int delay = 1000;
	public BGChanger(){
		super("Background Changer");
		setSize(300,300);
		setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		setVisible(true);
		ActionListener ac = new ActionListener(){
						public void actionPerformed(ActionEvent e){
							getContentPane().setBackground(Color.BLUE);
		Timer timer = new Timer(delay,ac);
		timer.start();
		public static void main(String args[]){
			BGChanger gui = new BGChanger();
Can anyone help me with this? This is just written for fun to gain my knowledge :)
SevenZero
Re: Help for my background color changer Java program
Post by SevenZero » Tue Mar 06, 2012 8:32 pm
I'll give you a tip on how to do it.
Define a variable say int curColour and set it to 0 at the constructor. Delete the line getContentPane().setBackground(Color.BLUE); and add something like below with function actionPerformed.
switch (curColour){
	case 0: //Blue
		break;
	case 1: //Red
		getContentPane().setBackground(Color.RED);
		break;
	case n: //XXXX  Last colour you need
		getContentPane().setBackground(Color.XXXX);
		break;
if (curColour == n){ // We reached last colour -> start from beginning  (replace n with the number for your last colour)
	curColour  = 0;
Post by Nipuna » Wed Mar 07, 2012 7:37 am
Hi
Thanks for the reply
But it is working same as before not changing according to seconds. after 1st second it become blue and then it doesn't change :?
Here is the new code
		  int curColour;
        public BGChanger(){
                setSize(300,300);
                setVisible(true);
                curColour = 0;
								switch (curColour){
       									case 0:
          								break;
       									case 1:
          								break;
       									case 3:
          									getContentPane().setBackground(Color.WHITE);
          								break;
    								if (curColour == 3){
       									curColour  = 0;
                timer.start();
Since we get those ugly marks in the syntax highlighting so I am attaching my code too. :) Since Expertcore doesn't let to attach .java files. I added a .zip file and inside that there is the .java file. ;)
BGChanger.zip
(628 Bytes) Downloaded 619 times
Post by Saman » Wed Mar 07, 2012 12:26 pm
Put timer.start(); again as the last line of function actionPerformed.
Post by Nipuna » Wed Mar 07, 2012 1:42 pm
Yeah :yahoo: I did few adjustments and got it to work.
I added timer.start() again but it didn't work so I did few changes and then it worked.
Thanks friends.
Here goes the new code
	private int curColour;
        private Timer timer;
        public BGChanger(){
                setSize(300,300);
                curColour = 0;
                Handler ac = new Handler();
                timer.start();
                        gui.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
                        gui.setVisible(true);
       private class Handler implements ActionListener {
              switch (curColour){
                  case 0:
                      curColour++;
                  break;
                  case 1:
                      curColour++;
                  break;
                  case 2:
                       curColour++;
                  break;
               if (curColour == 3)
                   curColour  = 0;
Return to “Java Programming”
