Google maps help
.NET programming topics
kodi
Corporal
Corporal
Google maps help
Post by kodi » Sun Oct 09, 2011 6:03 am
I want to use google maps in my site developed using visual studio(.net). I have found the code and learnt how to use it. Now I want to open the map in a new windows when a button is clicked. Since the google maps code is a javascript code I don't know how to use it with a button click (I am new to programming). I also want to pass two parameters from the database to use in coordinates of the map. what is the proper way to do this.
Re: Google maps help
Post by Neo » Sun Oct 09, 2011 5:55 pm
Though there are some guys who fetch Google map images from web for offline use, according to my memory it is illegal (Google only allows fetching their maps online). I came across a nice .Net cotrol written for Google Maps in CodeProject. I'm sure it will give you some help. Lat Lays Flat - Part 1 : A Google Maps .NET Control.
kodi
Corporal
Corporal
Post by kodi » Sun Oct 09, 2011 7:08 pm
I'm not using them Offline. I'm using the code given by Google themselves. I just need to know how to open the map in a new window when a button click is performed.
Herath
Post by Herath » Sun Oct 09, 2011 10:26 pm
Looks like you want to open a map in a new window. For this you will have to get familiarized with Google Maps API. It's easy.
Then you will need to add code to open up a new window and pass the coordinates to it as query strings or using any other method. I do not have ASP.NET installed to give it a try. The installer is giving an error. I will check if i could install it.
Enigma
Post by Enigma » Tue Oct 11, 2011 3:48 am
Hello
Try this sample. May help you out. Make sure to add your APIKEY to the script which is in the MapWindow.aspx
GoogleMapTest.zip
(132.28 KiB) Downloaded 1233 times
Reason: Attachment added to post
kodi
Corporal
Corporal
Post by kodi » Tue Oct 11, 2011 8:18 am
The code I use don't ask for a API key. This is the code
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1.0, user-scalable=no" />
<style type="text/css">
  html { height: 100% }
  body { height: 100%; margin: 0; padding: 0 }
  #map_canvas { height: 100% }
</style>
<script type="text/javascript"
    src="http://maps.googleapis.com/maps/api/js?sensor=true">
</script>
<script type="text/javascript">
    function initialize() {
        var myLat = 6.581481;
        var myLng = 79.96459;
        var latlng = new google.maps.LatLng(myLat,myLng);
        var myOptions = {
            zoom: 17,
            center: latlng,
            mapTypeId: google.maps.MapTypeId.ROADMAP
        var map = new google.maps.Map(document.getElementById("map_canvas"),
        myOptions);
</script>
</head>
<body onload="initialize()">
  <div id="map_canvas" style="width:100%; height:100%"></div>
</body>
</html>
Instead of hard coding the coordinates I want to pass them from a database. I can't call this javascript code from a button click in Visual Studio
Enigma
Post by Enigma » Tue Oct 11, 2011 12:04 pm
Hi
Made some alterations for the code. Try this.
GoogleMapTest(Edited).zip
(132.93 KiB) Downloaded 1176 times
Herath
Post by Herath » Tue Oct 11, 2011 8:05 pm
I also had time to do some modifications. Had little help from http://www.mikeborozdin.com/post/Workin ... SPNET.aspx
GoogleMapTest.rar
(122.12 KiB) Downloaded 1090 times
kodi
Corporal
Corporal
Post by kodi » Wed Oct 12, 2011 4:07 am
Thank a ton guys. This is exactly what I wanted :yahoo:
You guys were so helpful. Thanks again.
Return to “.NET Programming”
